[NEED HELP] Database corrupted
Hello guys !
I am scratching my head because since an unknown time, I can no longer research any movie or tv show in both Plex for TV and Plex for Windows.
And the PLEX Docker no longer add new downloaded content.
I have a database corruption apparently : How can I fix it
Jul 08, 2022 18:49:40.100 [0x148eca1c4b38] ERROR - [DatabaseFixups] SQLITE3:0x80000001, 11, database corruption at line 81887 of [1b256d97b5]
Jul 08, 2022 18:49:40.100 [0x148eca1c4b38] ERROR - [DatabaseFixups] SQLITE3:0x80000001, 11, statement aborts at 11: [SELECT idx, start_block, leaves_end_block, end_block, root FROM 'main'.'fts4_metadata_titles_icu_segdir' WHERE level = ? ORDER BY idx ASC] database disk image is malformed
Jul 08, 2022 18:49:40.100 [0x148eca1c4b38] ERROR - [DatabaseFixups] SQLITE3:0x80000001, 11, statement aborts at 163: [update metadata_items set extra_data=? where metadata_type=? and library_section_id=? and id=?] database disk image is malformed
Jul 08, 2022 18:49:40.100 [0x148eca1c4b38] ERROR - [DatabaseFixups] Exception inside transaction (inside=1) (/data/jenkins/server/3533312223/Library/MetadataCollection.cpp:481): sqlite3_statement_backend::loadOne: database disk image is malformed
Jul 08, 2022 18:49:40.100 [0x148eca1c4b38] ERROR - [DatabaseFixups] Fixup 29DatabaseFixupsSyncCollections threw an exception: sqlite3_statement_backend::loadOne: database disk image is malformed
Plex Media Server Logs_2022-07-08_19-22-15.zip (1.3 MB)
Plex Documentation → Repair a Corrupted Database
If repair fails, try Restore a Database Backed Up via ‘Scheduled Tasks’.
If neither repair nor restore works, then delete the database and recreate your libraries, shares, etc (mentioned in the “Repair…” support document).
