I’m currently running Plex on a Synology 218+, but decided I needed to do a dedicated build to really get the best experience as my use and volume grow (especially with the increased 4K content). I currently don’t have more than 2-3 streams at a time, but I do plan to share my library with more users and expand the amount of content available, so I want to build for the future.
I’ve built desktop PCs in the past but have a limited knowledge of advanced networking and network settings, and have not really used any operating system outside of Windows (other than the Synology DSM, and I’m still pretty noob on that). This build would basically be dedicated to PMS, although having some basic network filesharing would be nice as well.
So I’m considering these options on the new build, with my top choices on each topic, was hoping for some suggestions or opinions from the community.
*O/S: Windows 10, FreeNAS, or something else? (Leaning towards Windows just out of familiarity, but if there’s a better OS for Plex that doesn’t have a steep learning curve, I’m open to it).
*CPU/GPU: Was planning on a Ryzen 5 3600 / RX 580 8GB combo, seems to be a reasonable combo for performance and price. I do get the sense that the majority of Plex users/commentators prefer the Intel/Nvidia combo, so if there’s something comparable I’m open to it. I also don’t know if that combo is overkill for a dedicated media server, but I don’t want any hardware bottlenecks so I’m willing to overbuild slightly.
*Transcoding: RAM disk, SSD, or HDD? I have enough system memory (64GB) to allocate a good size RAM disk, but I’ve read mixed reviews on using it and whether it’s worth it. I could alternatively dedicate an SSD or HDD for transcoding use, to keep that workload away from my storage and OS drives. What size would be advised if going the SSD/HDD route?
*Drive Configuration: My plan was to run the O/S off of an NVME drive, use a 2nd NVME drive for the Plex db/cache, and then have a 6 HDD RAID6 array for the media storage. Is there an alternative recommended? My MOBO allows for 2 NVME (the newer faster PCIe 4.0 spec), and 8 SATA III ports, so I have a lot of configuration options.
The reason I mentioned FreeNAS is that I had seen many people comment it was a fairly easy solution for network file sharing, was an easy to use file system to manage the storage arrays, and could also run Plex well, and exclusively web-interface (like the Synology). But again I know very little about that operating systems, so I’m not looking to get in over my head.
Thanks in advance for any suggestions and input!
