New movies suggestion with machine learning: movielens.org
Hi all,
how can I discorver new movies to add to my library based on my tastes?
I’ve found movieslens which suggest you new movies. I would like to add my personal ratings in Plex directly in movieslens. I was able to export the .csv containing the info needed but there is something in the .csv format which doesn’t fit with the expected format, bau I can’f figure out what it is. It’s becoming frustating…
Does anyone could do that?
