New official Channels for AppleTV
It looks like Yahoo Screen and PBS channels have been added to AppleTV: <http://www.macrumors.com/2013/11/19/yahoo-screen-and-pbs-come-to-apple-tv/>
As per other channel pushes, I'm guessing this does not cause PC any problems, but would appreciate it if anyone has the updated channels to comment that it does not bork anything.
Plexconnect on iMovie Theatre still works. PBS access is very slow at the moment but Yahoo Screen works smoothly.
Looks like ATV interface will be going flat like iOS 7, after all. Both new icons lack gradients or other visual indicators of depth.
What about PlexConnect on Trailers app, or are / have we moved away from using that?
PBS is slow because there are quite a few people activating things, obviously demand is a little higher than expected.
I've been digging around to find out how you create an account / activate and found that once you access the app, you get a code, and need to go here to set things up: http://video.pbs.org/activate/
The Macrumors article did not mention that link, but another article from another site did. Thought I'd post it as it might be handy for others.
I am just currently on iMovies theatre. Taking it for a spin.
I might have a dip into that pool when I have a chance, I would quite like the trailers app back.
So it is confirmed that is OK to update? Having yahoo/PBS doesn’t break PC, right?
You have no choice but to update do you? It is not a firmware update, as already mentioned. But no nothing bad happened.
How did you switch to the iMovie theater instead of Trailers?
Check this thread;
https://forums.plexapp.com/index.php?/topic/86012-How-to-use-iMovie-Theater-instead-of-the-Trailers-app
