To add a datapoint, I have found the DS918+ to handle all but the most demanding 4k files without issues.
All of the Jellyfish videos worked for me (90/120/200 Mbps HEVC 10-bit tested) at about 35% CPU usage including I/O overhead from the RAID 5 array the media is streaming off of. 400 Mbps was barely too much (stuttering every 20 seconds, about 0.9 transcoding speed).
Planet Earth in 4K HDR (40 Mbps HEVC encode) played fine as well.
Results were verified on an iPhone, AppleTV, and NVIDIA Shield TV, all set to convert at maximum quality. I wasn’t able to get Plex Web to work with the files.
My unit is equipped with 16 GB RAM and 240 GB m.2 NVME SSDs in a RAID 1 R/W cache.
For Playback I am using an AppleTV 4th gen with most current Plex App. AppleTV and NAS are connected via GigaBit network cable. No Wifi involved.
First I tested with PMS 1.09 and without hardware acceleration. CPU is at 99% and constant stuttering, buffering etc. For testing purposes I ordered a month of Plex pass, to be able to upgrade to PMS 1.10. I enabled hardware acceleration in the Server → Transcoder settings. CPU usage dropped to around 35% and playback is fine for about 1-2 minutes. After that the picture quality drops drastically, looks like a 320p video on my 46’’ TV. Sometimes the picture looked normal, but short stuttering.
The Jellyfish sample files were running fine. But I assume, this was only because they are 30s short.
I played around with various PMS settings:
Settings → Web → Quality
disabled / enabled automatic quality
video quality set to maximum or 20mbps
enabled / disabled recommended settings for home streaming
Settings → Web → Debug
enabled direct play
enabled direct stream
Settings → Server → Transcoder
transcoder quality automatic and higher speed
I could not watch the sample movie without any glitches
@ChuckPA said:
At this point, only software decoding of MPEG2 for anyone.
This is where Plex fails for me on any Synology and trying to watch live tv or playback any recorded shows. I’ve switched over to using Channels DVR and Infuse for any playback on my Apple TV 4k because they can play those files with ease. Plex client has always struggled for whatever reason, even with direct playback.
Thanks @ChuckPA When you say Engineering, you mean Plex engineers, or Synology? This has plagued any Plex installation that I have tried, the playback of Live TV or recorded TV. Just seems crazy that the other two apps I mentioned have no issues playing back the same content.
When I reference “Engineering”, I am speaking of our Engineering team.
Were I refer to Synology in any way, I state it as “Synology”.
It is also important to understand the maturity level of Live TV & DVR at Plex. It was introduced as a development beta a branch of PMS 1.6.0 whereas I started using PMS four years ago. Yes, it has some issues but given where it’s come from 1.6.x to now (1.10.x), it’s made huge progress.
Hi
Can I ask for some advice / help please.
I have an old DS213Air that used to run Plex (slowly) but that stopped being supported earlier this year.
I’ve just bought a DS918+ and I’m getting it setup and getting Plex server installed on it. My TV is a Sony Bravia. My computer & phone are apple devices. I don’t have Apple TV.
If I want to make use of the HDR capability of Plex, how do I do it using my DS918+ - what else to I need to buy to make this work?
I see in your profile that you are not a plex pass user. You need a plex pass membership also to use the dvr feature along with the hardware transcoding capabilities.
thanks - yes I was aware of that. I’m trying to work out how much I do want to use Plex - especially as it won’t work with my current DRM media - and I’ll have to convert it to be able to view which is a real pain.
Would the 918+ handle 720p and 1080p content/transcoding better than a 1515+ with its hardware decoder? Wondering if I would gain by getting a 918+. We don’t have any HEVC content yet
absolutely. The DS1515 is an atom C2538 CPU (like the DS1815+) which cannot effectively do any video transcoding. Audio is the best it can manage until it’s audio in a HEVC stream. At that point it dies. It cannot decode the HEVC stream
Those who are encountering problems with these NAS units to please create your own thread so I may properly address it.
This thread is 11 pages long now and tough to navigate
