When im on my Plex i can see if anyone else is on at the same time. Anyway to see what and if any of my friends have watched when i wasnt on?
That’ll get you there. This is the built-in simple version.
Chris
Thx for the reply, turns out you need Plex Pass im running free version.
Check out Tautulli. Play history and much more.
TY it looked great but i found Github too confusing to use ![]()
If you’re on Windows then Tautulli is simply an .exe file with a startup wizard.
Though Tautulli has an incredible amount of options, in its basic form it’s very simple to set up.
That would be great and super easy but the link gave me options for google play/app store and github and on github it wasnt real clear where or how to get it, i tried installing gituhub on my pc it was confusing. do you have a link to the exe file for Tautulli? Thx for your help!
Scroll to the bottom of this page.
Look for the Windows.exe (in assets)
Github’s a pain to use. It’s primarilly a source-code repository. It is not easy for me to find if there are pre-compiled windows binaries available on a github repository. You’d expect it up near the top, but they bury it farther down in the pages.
Thank you very much Im set up! ![]()
