Server Version#: Current Plex version: 1.14.1.5488-cc260c476 Dec 25, 2018
Player Version#: Newest on several devices
Hi!
I have a really annoying problem that i would like to get fixed. My server works perfectly fine, for 1-3 days, then it suddenly doesn’t. This just happens without anything i can connect as the problem.
Its never in the middle of a viewing but between. And if i check and uncheck plex it doesn’t work. If i try usually i get “database corrupted, rebuild” or something like that. The only way to make it work is restarting but i have a lot of devices that i also need to restart when i do that and its really annoying.
Can you please tell me if you have someone else with the same problem?
