Not Authorised Error, Prefereces.xml is empty already?
I am using a Docker instance from DockerHub and is updated to latest.
I have fixed a few issues in the last few hours trying to access my library but I’ve hit another wall.
If I use the IP to access the server it asks me for a login, I do this, the same one I used before and it tells me I am not authorized to access this server. So based on this article https://support.plex.tv/articles/204281528-why-am-i-locked-out-of-server-settings-and-how-do-i-get-in/ I tried to clean up my preferences to fix it.
But when I found this file it’s mostly empty already:
/srv/dev-disk-by-uuid-29b1084b-a7f3-432d-99b9-1f71e9a2c383/Stuff/Config/PlexConfig/Library/Application Support/Plex Media Server# cat Preferences.xml
<?xml version="1.0" encoding="utf-8"?>
<Preferences OldestPreviousVersion="1.27.0.5897-3940636f2" MachineIdentifier="AAA" ProcessedMachineIdentifier="XXX" AnonymousMachineIdentifier="YYY" MetricsEpoch="1" GlobalMusicVideoPathMigrated="1" TranscoderTempDirectory="/transcode"/>
Am I following the wrong instructions, or is this the wrong file? As far as I can see this right.
