OpenPHT startup library configurable?
Brilliant piece of software, but is there any way to set what Library is selected on startup? It always defaults to “Search” but I’d like to choose my own, such as “Movies”?
currently no, but you can make it go to a random library if you are using the aeon nox skin and you customise / remove some of the openpht menus like search from the home bar, it will load up on a random library instead of search, mine loads to the home videos library which i like more than search
@daniel.cull Thanks.
