Opensubtitles misspelling language id
Hi there,
I'm trying to use the opensubtitles to auto download them and I notice from the log file that the opensubtitles agent did not fetch correctly the language id
My language is Greek and at the log file I see that the agent is trying to fetch with the id "gre" ( No subtitles available for language gre )
After looking the opensibtitles.org site I found that for Greek language the id is "ell" and not "gre".
While looking the file DefaultPrefs.json in the directory "Plug-ins/OpenSubtitles.bundle/Contents/" I notice the dictionary in the list is incorrect and listing the id "gre"
I changed the id in this file and then the agent worked correctly as expected, I finally have auto download the subtitles for my language.
After using that config for a day, I notice that I had the same issue and the file had changed to the native config. So I believe that the file is auto-created by something else every time the agent is trying to auto update.
Can someone help me find the exact file that is needing change to permanently correct the issue ?
Thank you in advance
Same problem here, also for greek language. I am using the windows version and the problem is the same. I edit the files to 'ell' from 'gre', works for a while and after some time resets to default. Auto-updating was my guess too but I cannot find a solution. Please fix.
Default bundles are updated automatically by PMS when launched. They would have to correct this on the dev side.
Sent from my SGH-T959V using Tapatalk
I've just changed the Greek language abbreviation to "ell" and pushed out an updated OpenSubtitles Agent. The update will be downloaded by your PMS automatically.
