Optimized versions naming problem (multiple per day / olympics)
It appears that the latest beta of Plex Server uses a naming scheme of YYYY-MM-DD.mp4 when creating optimized version of the Olympics US/NBC broadcast, which has multiple shows per day. This is likely not going to allow for a good outcome.
Can you show an example of the file name before optimizing and after?
Sure. These files were created by going through the Plex DVR interface to make a series recording and optimized versions. I had no direct hand in creating the filenames or directory names:
…/Plex/TV Shows/2018 Winter Olympics (2018)/Season 2018/2018 Winter Olympics (2018) - 2018-02-13 00 00 00 - Men’s Alpine Skiing Men’s Snowboarding.ts
…/Plex/TV Shows/2018 Winter Olympics (2018)/Season 2018/2018 Winter Olympics (2018) - 2018-02-13 15 00 00 - Speed Skating Luge Cross-Country Skiing.ts
…/Plex/TV Shows/2018 Winter Olympics (2018)/Season 2018/2018 Winter Olympics (2018) - 2018-02-13 20 00 00 - Figure Skating Alpine Skiing Snowboarding.ts
…/Plex/TV Shows/2018 Winter Olympics (2018)/Season 2018/Plex Versions/Optimized for TV/2018 Winter Olympics/2018-02-13.mp4
I’m not sure which episode has been optimized, and it looks like it’s currently working on another one:
…/Plex/TV Shows/2018 Winter Olympics (2018)/Season 2018/Plex Versions/Optimized for TV/2018 Winter Olympics/.inProgress/2018-02-13.mp4.944
Yep, it’s mangling the names for sure. This is for “Optimize for TV” profile correct?
Out of curiosity could you try a different profile (perhaps any mobile) and convert 1 file and see if mangles the name as well?
For the Optimize for TV if you are changing any of the default options could you post screen shots of the settings you use.
Once I hear back from you I’ll open a trouble ticket and bring this to the attention of the devs.
Carlo
Yes, this is the default “Optimize for TV” profile.
I tried the default “Optimize for Mobile” profile and got a similar filename:
../Plex/TV Shows/2018 Winter Olympics (2018)/Season 2018/Plex Versions/Optimized for Mobile/2018 Winter Olympics/2018-02-15.mp4
I have not changed any of the default options.
Thanks for offering to submit this to the devs through official channels.
I am having this issue as well and am seeing the same naming conventions as j14r. Using PMS 1.11.3.4803 and “Original Quality” profile for optimizer. As the optimizer is saving to the same file name, only one optimized version exists at a time for shows with multiple broadcasts of the same name in a single day (Olympics).
