Alright, I see. I will just wait for possible fixes and thank you for all of your help and time so far! Highly appreciated
If 1.19.6 is released we can upgrade via the official upgrade channel, I suppose?
Yes - so long as the build number is higher (and it will be) then it would work
Thank you very much again <3 Will have a few coffees until then and sit back and relax
An update - The changes to curl caused a regression and curl pulled back the change - the regression affected sftp - not directly impacting Plex Media Server use of curl
The fix in curl is being changed and will go through the review process for curl. This does mean that 1.19.6 beta may not have the changes that are in the development build that i sent out.
I will let you know if there is a new build - that would be after curl approve the new changes and make a new curl upgrade available.
