Hey eliabeandrade, sorry for the late reply. I'll try to put something together to better help you. I'll PM you, so we can keep the noise out of this thread.
ok
ok
<?php
require_once('Plex.php');// Then you can pretty much follow the README$servers = array('name-of-server' => array('address' => '127.0.0.1'));$plex = new Plex();$plex->registerServers($servers);$server = $plex->getServer('ServerPlex');?>
Fatal error: Uncaught exception 'Plex_Exception_Server' with message 'The server "ServerPlex" can not be found.' in C:\xampp\htdocs\plex3\Plex.php:174 Stack trace: #0 C:\xampp\htdocs\plex3\index.php(24): Plex->getServer('ServerPlex') #1 {main} thrown inC:\xampp\htdocs\plex3\Plex.php on line 174
peopl help please
Hey eliabeandrade,
Sorry I've been a bit absent lately. Instead of this:
$servers = array(
Try this
$servers = array(
'ServerPlex' => array(
Also make sure that SeverPlex is the correct name of the server. Is this the name that shows up at the top right of the screen when you use the standard Plex client? Also, it looks as if you are running your PHP on the same machine you are running Plex Server. Is this correct?
Hi guys,
I'm getting this error:
Strict Standards: Declaration of Plex_Server_Library_ItemAbstract::getPolymorphicItem() should be compatible with Plex_Server_Library_SectionAbstract::getPolymorphicItem($polymorphicData, $scopedToItem = false) in /path/to/php-plex/Server/Library/ItemAbstract.php on line 41
Any idea why?
