Plex Export creates a local copy of your Plex library that you can share without requiring access to the media server. Uses PHP to generate a HTML/JavaScript website with multiple sections, live filtering and media information.
Cover art is included, I’m just working on the best way to resize it to fit. As for imdb etc I’m going by what’s returned by the api so I shall have to see.
Made some progress today on visual mockups for how it may look. Dribbble’d some preview shots as well, must put up a full preview when I’ve started on the HTML.
Edit: If any Plex staff members are reading this; what’s the policy on re-using existing Plex assets (primarily logo and media type icons)? I’m trying to stay true to the default Plex interface but can change if necessary.
Very cool. I like what I see Probably the best thing to do would be to PM Elan to get permission to use those assets. It would be just a formality really
[]Only tested in Safari/Chrome/Firefox (latest). As Plex is (currently) Mac only, IE is a lower priority however I do want it to work across browsers where possible.
[]Data is loaded in via JavaScript. This still needs a lot of work for efficiency purposes (live filtering for example). Also, will remove JSONP chain.
[]Positioning bugs of the popup (written very quickly hence lack of general checks)
[/list]
Features still to add:
[list]
[]Additional item information: genres, seasons/episodes for shows, support for additional media types.
[]Additional filters for genres, ratings etc (similar to Plex itself)
[]Make the exporter itself much more robust, it currently just spits out a JSON file and the raw image data. Got to resize images etc etc.
[/list]
If anyone finds any bugs or has feature suggestions, please add them/PM me! I’m going to release the exporter tool as soon as it’s up to a workable state, it will however be in very early stages so I’ll need some willing volunteers with large and diverse libraries to help test it out, again PM me if you’re interested.
This is great and absolutely beautiful! I think your Photoshop skills are awesome, no need to change anything on the design… Looking forward to fetch the exporter tool somewhere!
Okay, the first alpha is now available for download. Again, this is ALPHA quality. I’ve tested it with only my own library at the moment so I’m mainly looking to see how well it handles others (foreign characters, multiple collections etc). If people can post anything they notice below I can get fixing.
The zip file contains the HTML template and necessary assets along with the command line PHP script to generate the data. The README file should get you started but if you have any problems just let me know.
That looks really cool! very easy to install, and it works just fine. Thanks so much for that!
Now we just need to integrate that with the PMS to allow updating from a browser
Is it possible to extract the file quality as well?
Finally, would it be possible to have a “update from library” button, maybe requiring a password to avoid people doing it just for fun. Or on an admin page, just to make it easier to keep it up to date. Assume that you would just run the “php cli.php -plex-url=http://other-machine.local:32400” command to update the library information.
Maybe link to the imdb/moviedb site for each movie?
but, thank you for this. Looks really good for an alpha release
When running on a remote computer using the -plex-url= string, does it work when you use a username and password for the Plex Media Server? Probably not… (yet)?
@mkh can you confirm there is a plex-data directory?
@MrAcid I haven’t tested it with authentication yet, I doubt it will work as is. Will be a feature to add asap.
@henrk File information is available, I just need to extract it and display it. For updates it is just a case of re-running the cli script so I’ll look into that. And lastly, I can’t find any IMDB data via the API yet so I’m still hunting for the best way to do that.
mini:~ mini$ php /Users/mini/Desktop/plexexport/cli.php
14:24:45 Welcome to the Plex Exporter v1
14:24:45 Searching for sections in the Plex library at http://localhost:32400/
14:24:45 Found 5 valid sections out of a possible 6 sections in this Plex library
14:24:45 Scanning section: Documentary
14:24:45 Found 5 movies in Documentary
14:24:45 Scanning movie: Area 51: The Real Story
14:24:45 Error: imagepng(): Unable to open 'plex-data/thumb_1601.png' for writing: No such file or directory on line 370
14:24:45 Scanning movie: The Bob Lazar Tape
14:24:45 Error: imagepng(): Unable to open 'plex-data/thumb_1606.png' for writing: No such file or directory on line 370
