Playlist Thumbnails do not show on Plex when imported from iTunes
Server Version#: Version 3.77.4
A minor but annoying issue which it would be good if you could fix.
When Playlists are imported from iPlayer the thumbnails created by Plex for each playlist don’t display correctly. Some only partially display and it seems that Plex creates one thumbnail and then displays the same image/thumbnail for several playlists.
It only seems to be an issue for “Smart Playlists” but not all “Smart Playlists”
