Please change cURL library to use OS certification storage
My company has firewall and do SSL sniffing for detect leakage of confidential information.
Every PC installed custom certification on OS by windows group policy.
but… Plexamp use cURL library, and use own certification by default.
and plexamp connect using https always fail by certification error.
I can’t use plexamp now. (probably plex for windows too…)
but cURL can change certification backend, like schannel or secure transport.
(use OS’s certification storage. need change build option and rebuild)
https://curl.se/docs/sslcerts.html
Is there someone plex developer there, please consider change cURL binary.
Solved. but I want support it from plexamp.
  1. Export company’s DPI solution CA certification from OS’s key storage (BASE64 .cer format)
  2. change .cer to .pem
  3. append .pem to %LOCALAPPDATA%\Programs\Plexamp\resources\cacert.pem
  4. restart Plexamp and login.
