IceOnFire7 commented 21 hours ago
I’m attempting to setup Apache via windows 2008 to redirect Plex ATV 3 traffic to port 9999 instead of 80, which I’m using to host my domain. The ATV connects to the Plex Server perfectly with Apache disabled. However, when I connect via Apache redirect, I am getting the Trailers is not available error on my ATV. The only thing I may be missing is a VirtualHost entry for port 443, but I am not certain. Any suggestions?
Here is my Plex config:
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.0.2
port_pms = 32400
enable_dnsserver = False (local DNS service running in Windows)
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 9999
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
loglevel = High
logpath = .
Here is my Apache Config:
ServerName plex.domain.com
Order deny,allow
Allow from all
ProxyRequests Off
ProxyPreserveHost On
ProxyPass / http://127.0.0.1:32400/
ProxyPassReverse / http://127.0.0.1:32400/
RewriteEngine on
RewriteCond %{REQUEST_URI} !^/web
RewriteCond %{HTTP:X-Plex-Device} ^<br>
RewriteRule ^/ /web/$1 [R,L]
ServerName trailers.apple.com
RequestHeader set User-Agent AppleTV
ProxyRequests off
AllowEncodedSlashes NoDecode
ProxyPass / http://trailers.apple.com:9999/ nocanon
ProxyPassReverse / http://trailers.apple.com:9999/
Sent from my iPad using Tapatalk
Hi IceOneFire,
I'm no expert, so I can't give you any real advice, but after playing around with my apache configuration for a few hours, I finally got it to work with PlexConnect. My files are below...maybe something in there will help you out.
PlexConnect Settings.cfg
enable_plexgdm = False
ip_pms = 192.168.1.104
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 192.168.1.1
enable_plexconnect_autodetect = False
ip_plexconnect = 192.168.1.104
port_webserver = 8080
port_ssl = 4443
certfile = /home/"user"/PlexConnect/PlexConnect/assets/certificates/trailers.pem
loglevel = High
logpath = /home/"user"/PlexConnect/PlexConnect
Apache - note that there are two virtual hosts for port 80. One server name is trailers.apple.com and the other is atv.plexconnect
Hi IceOneFire,
port_pms = 32400
port_dnsserver = 53
port_ssl = 4443
loglevel = High
ServerAlias atv.plexconnect
ProxyRequests Off
Order allow,deny
Allow from all
ProxyPass / http://192.168.1.104:8080/ nocanon
ProxyPassReverse / http://192.168.1.104:8080/
ServerName atv.plexconnect
ProxyRequests Off
Order allow,deny
Allow from all
SSLProxyEngine On
ProxyRequests Off
Order allow,deny
Allow from all
ProxyPass / https://192.168.1.104:4443/ nocanon
ProxyPassReverse / https://192.168.1.104:4443/
SSLEngine on
SSLProtocol -ALL +SSLv3 +TLSv1
SSLCipherSuite ALL:!ADH:RC4+RSA:+HIGH:+MEDIUM:!LOW:!SSLv2:!EXPORT
SSLCertificateFile /home/"user"/PlexConnect/PlexConnect/assets/certificates/trailers.cer
SSLCertificateKeyFile /home/"user"/PlexConnect/PlexConnect/assets/certificates/trailers.key
CustomLog ${APACHE_LOG_DIR}/proxy_ssl_access.log combined
Hope this helps!
Note ATV.plexconnect host is now longer required in the latest versions. (For a few months now)
Thanks for the update!
I copied your config for Plex and Apache, but unfortunately I am getting "Trailers Not Available".
Hi Guys,
can anybody please post the working apache proxys for port 80 and port 443.
Cheers Robert
Thanks tkimball83.
I will try it.
Hi tkimball83,
i tried your settings yesterday but unfortunately it is not working.
Does anyboady had owncloud and plex running together?
Cheers Robert
Robert, I was in your same situation. Finally got it up and running. Full writeup on my working solution (Apache on port 80/443, ownCloud, and PlexConnect) can be found over on my blog. http://www.linuxtoolbox.ninja?p=60
