Hi All,
I’m trying to install Plex Server on my Raspberry Pi 4+ with Docker in OMV5 but is not starting when i browse to the webserver.
Please find attached the log.
Many thanks for your help
Server Version#:
(File removed)
Hi All,
Server Version#:
(File removed)
Step 1: fix the time of that server… all logs pointing to Jan 1, 1970 implies that the server’s time has never been set at all.
Hi tom80H,
many thanks for your response. I’ve seen that, but I don’t know how to fix it. I cannot do anything on the webgui and i’ve just installed using the compose text found in this website
If i log in to OMV the date and time is correctly set.
How can I fix the time and date on plex server?
Many thanks.
Thank you so much. Changing it to bionic worked and now I’m configuring my server.
Thanks!!!
