Server Version#: 1.19.5.3035
Player Version#: 4.37.1
I’m seeing lots of errors for what seems like every show I have:
[Notify] Failed to add watch for "<path>" (28: No space left on device)
There is plenty of free space on the server and I double checked that permissions are okay (full read/write) but the directories are still owned by my primary user account.
I’m assuming this was due to having too many folders for Plex to index, and I don’t care if it indexes Music or Photos frequently but couldn’t find a way to turn off monitoring those, so I deleted Photos library from Plex and so far haven’t seen the issue return. Alternatively, I imagine I could increase the iNotify value as a scheduled task, but want to avoid that.
If you can run a count (use FileStation → Properties) and obtain the sum of all the monitored directories, we can increase the table size to accommodate this.
For the benefit of anyone else who finds this:
If you have media in the Plex share, please move it out now.
It doesn’t belong there.
I created the share to hold metadata because the default location afforded by Synology was too small. It was also originally hidden. I made it visible to allow retrieval of log files and database repairs when PMS won’t start correctly.
I am considering a change which will remove the restriction but, for now, I do need to keep no media there. ( I did post warnings in 6 languages)
The catastrophic failure which occurs is because PMS , which has 4-5 directories for each media item, modifies them.
If you take all your media files and multiply by 5, you get a catastrophic escalation because PMS starts monitoring itself… Infinite loop.
Your issue is common when a lot of photos or music is involved. When either are properly structured, directory counts sore. 8192 is nothing. It’s not uncommon to see a max_users_watches value of 262144 (256k directories).
