Plex Crashing constantly several times a day
Server Version#: Version 1.30.1.6497 (reverted from 1.30.2.6563)
Player Version#: all players
Plex Media Server Logs_2023-02-01_18-59-49.zip (6.0 MB)
I am getting several crashes in a day where I am forced to restart the server to use Plex. I tried reverting Plex version to a previous one.
I also tried disabling scheduled task for “Analyze audio tracks for sonic features” and “Analyze audio tracks for loudness” in scheduled tasks. It seems to crash even when not in the scheduled task window.
I’m not sure what it could be, and it’s crashing quite often now. There seems to be an XML error in the logs attached. Anyone know what could be the cause?
The XML error is not a problem. You can ignore that.
I’m seeing something is pulling data from your server repeatedly and it’s clogging up the database. I see you are also using Tautulli and some other unknown device. Do you have other 3rd party tools installed. It’s possible it’s one of these. Turn them off temporarily and see if PMS stabilizes. Then turn them back on 1 by one to see if you can find when it breaks.
Thanks for looking at that. I paused third party apps to see if that helps. So far no crashes fingers crossed
