I’ve been running my Plex server without issue for many many years. I’m running it on enterprise level hardware (EPYC 7443P, Nvidia a4000 (hw accel), RAID10 Optane 905p drives for plex appdata. All of a sudden over the past week or so, my Plex server has been crashing during peak usage (9-10pm). Sometimes it recovers on it’s own after a few minutes, sometimes I have to restart the docker container to bring it back. Please see the attached logs.
There are a lot of errors in the Plex Media Server.3.log file you attached. The slow query warnings are also of interest. The debug level will provide additional details.
When you restart PMS it bumps the log files. Plex Media Server.log → .1.log, .1.log → .2.log, etc. (.5.log → bit bucket).
So, after a restart, Plex Media Server.log will have the startup sequence, to show if there are any issues when PMS starts. The bottom of Plex Media Server.1.log will show what was happening when it crashed.
Verbose level logs are rarely needed. Enabling verbose level adds a lot of information to the log files. It makes them more difficult to read. It also causes them to wrap much faster, possibly losing desired information.
I was concerned about the slow query warnings as well. I’ve run the DBRepair utility multiple times over the past few weeks but that does not seem to have resolved the issue. Hopefully I’ll get more detailed info with the debug logs from the next crash.
perform a dd if=/dev/sdXX of=/dev/null bs=4M count=20000 status=progress
test of the device holding the Plex data (not the OS). (edit ‘XX’ appropriately)
DBRepair will put the DB in perfect contiguous and sorted order.
If there are still a lot of “SLOW QUERY” statements then
– The device’s performance might be the issue
– The number of “metadata_items” stored in com.plexapp.plugins.library.db could indeed be extreme
If the SLOW QUERY happens when this type audio is transcoding… then there are other issues
– Choice one is to reload the codecs
– Choice two is crappy media.
– Choice three is the hardware
This output tells me: Damaged Codecs or Bad Media.
Apr 25, 2024 04:16:03.548 [140710532324152] ERROR - [Req#925342/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] Error while decoding stream #0:1: Invalid data found when processing input
Apr 25, 2024 04:16:03.548 [140711167306552] ERROR - [Req#925343/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] [aac @ 0x7f0e87313ac0] Number of bands (67) exceeds limit (42).
Apr 25, 2024 04:16:03.548 [140711078337336] ERROR - [Req#925344/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] Error while decoding stream #0:1: Invalid data found when processing input
Apr 25, 2024 04:16:03.549 [140710532324152] ERROR - [Req#925345/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] [aac @ 0x7f0e87313ac0] Pulse data corrupt or invalid.
Apr 25, 2024 04:16:03.549 [140711167306552] ERROR - [Req#925346/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] Error while decoding stream #0:1: Invalid data found when processing input
Apr 25, 2024 04:16:03.549 [140711078337336] ERROR - [Req#925347/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] [aac @ 0x7f0e87313ac0] Pulse data corrupt or invalid.
Apr 25, 2024 04:16:03.549 [140710532324152] ERROR - [Req#925348/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] Error while decoding stream #0:1: Invalid data found when processing input
Apr 25, 2024 04:16:03.549 [140711167306552] ERROR - [Req#925349/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] [aac @ 0x7f0e87313ac0] Number of bands (61) exceeds limit (42).
Apr 25, 2024 04:16:03.550 [140711078337336] ERROR - [Req#92534a/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] Error while decoding stream #0:1: Invalid data found when processing input
Apr 25, 2024 04:16:03.550 [140710532324152] ERROR - [Req#92534b/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] [aac @ 0x7f0e87313ac0] TNS filter order 18 is greater than maximum 12.
Apr 25, 2024 04:16:03.550 [140711167306552] ERROR - [Req#92534c/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] Error while decoding stream #0:1: Invalid data found when processing input
Apr 25, 2024 04:16:03.550 [140711078337336] ERROR - [Req#92534d/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] [aac @ 0x7f0e87313ac0] Number of bands (15) exceeds limit (12).
Apr 25, 2024 04:16:03.551 [140710532324152] ERROR - [Req#92534e/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] Error while decoding stream #0:1: Invalid data found when processing input
Apr 25, 2024 04:16:03.551 [140711167306552] ERROR - [Req#92534f/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] [aac @ 0x7f0e87313ac0] Number of bands (52) exceeds limit (42).
Apr 25, 2024 04:16:03.551 [140711078337336] ERROR - [Req#925350/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] Error while decoding stream #0:1: Invalid data found when processing input
Apr 25, 2024 04:16:03.551 [140710532324152] ERROR - [Req#925351/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] [aac @ 0x7f0e87313ac0] Number of bands (65) exceeds limit (42).
Apr 25, 2024 04:16:03.551 [140711167306552] ERROR - [Req#925352/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] Error while decoding stream #0:1: Invalid data found when processing input
Apr 25, 2024 04:16:03.552 [140711078337336] ERROR - [Req#925353/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] [aac @ 0x7f0e87313ac0] TNS filter order 26 is greater than maximum 12.
Apr 25, 2024 04:16:03.552 [140710532324152] ERROR - [Req#925354/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] Error while decoding stream #0:1: Invalid data found when processing input
Apr 25, 2024 04:16:03.553 [140711167306552] ERROR - [Req#925355/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] [aac @ 0x7f0e87313ac0] Number of bands (46) exceeds limit (42).
Apr 25, 2024 04:16:03.553 [140711078337336] ERROR - [Req#925356/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] Error while decoding stream #0:1: Invalid data found when processing input
Apr 25, 2024 04:16:03.553 [140710532324152] ERROR - [Req#925357/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] [aac @ 0x7f0e87313ac0] Number of bands (44) exceeds limit (42).
Apr 25, 2024 04:16:03.554 [140711167306552] ERROR - [Req#925358/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] Error while decoding stream #0:1: Invalid data found when processing input
Apr 25, 2024 04:16:03.554 [140711078337336] ERROR - [Req#925359/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] [aac @ 0x7f0e87313ac0] Pulse data corrupt or invalid.
Apr 25, 2024 04:16:03.554 [140710532324152] ERROR - [Req#92535a/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] Error while decoding stream #0:1: Invalid data found when processing input
Apr 25, 2024 04:16:03.554 [140711167306552] ERROR - [Req#92535b/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] [aac @ 0x7f0e87313ac0] Number of bands (16) exceeds limit (12).
Apr 25, 2024 04:16:03.554 [140711078337336] ERROR - [Req#92535c/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] Error while decoding stream #0:1: Invalid data found when processing input
Apr 25, 2024 04:16:03.555 [140710532324152] ERROR - [Req#92535d/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] [aac @ 0x7f0e87313ac0] Number of bands (51) exceeds limit (42).
Apr 25, 2024 04:16:03.555 [140711167306552] ERROR - [Req#92535e/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] Error while decoding stream #0:1: Invalid data found when processing input
Apr 25, 2024 04:16:03.555 [140711078337336] ERROR - [Req#92535f/Transcode/5a03277d-c6cf-445d-9193-c7dd3b01b5f5/6975d362-89ab-4f97-b03c-38db28adf486] [aac @ 0x7f0e87313ac0] Number of bands (45) exceeds limit (42).
As I said in my OP, I’m running my plex appdata on a RAID10 zpool of 4 x Intel Optane 905p NVMe’s. Here is the performance of each of them indvidually. Reads should be roughly 4 times the speed of one of these tests given it’s a RAID10 pool.
# dd if=/dev/nvme1n1 of=/dev/null bs=4M count=20000 status=progress
81713430528 bytes (82 GB, 76 GiB) copied, 37 s, 2.2 GB/s
20000+0 records in
20000+0 records out
83886080000 bytes (84 GB, 78 GiB) copied, 37.985 s, 2.2 GB/s
# dd if=/dev/nvme2n1 of=/dev/null bs=4M count=20000 status=progress
81763762176 bytes (82 GB, 76 GiB) copied, 37 s, 2.2 GB/s
20000+0 records in
20000+0 records out
83886080000 bytes (84 GB, 78 GiB) copied, 37.9895 s, 2.2 GB/s
# dd if=/dev/nvme3n1 of=/dev/null bs=4M count=20000 status=progress
81705041920 bytes (82 GB, 76 GiB) copied, 37 s, 2.2 GB/s
20000+0 records in
20000+0 records out
83886080000 bytes (84 GB, 78 GiB) copied, 37.9899 s, 2.2 GB/s
# dd if=/dev/nvme6n1 of=/dev/null bs=4M count=20000 status=progress
81939922944 bytes (82 GB, 76 GiB) copied, 37 s, 2.2 GB/s
20000+0 records in
20000+0 records out
83886080000 bytes (84 GB, 78 GiB) copied, 37.8899 s, 2.2 GB/s
How do I determine how many metadata items are in com.plexapp.plugins.library.db and how many is considered extreme?
How do i reload the codecs? Simply delete the codecs directory and restart plex? I can’t see why it would be my media. Most of my media is high quality. Majority are remuxes.
To obtain the count of total indexed media items.
– cd into the ‘Databases’ directory
– sqlite3 com.plexapp.plugins.library.db
– select count(*) from media_items;
– select count(*) from metadata_items;
Looks like this:
[chuck@glockner Plex Media Server.2000]$ cd Plug-in\ Support/Databases/
[chuck@glockner Databases.2001]$ sqlite3 com.plexapp.plugins.library.db
SQLite version 3.37.2 2022-01-06 13:25:41
Enter ".help" for usage hints.
sqlite> select count(*) from media_items;
177768
sqlite> select count(*) from metadata_items;
162917
sqlite>
add the results for number of records. media_items represents actual pieces of media.
# sqlite3 com.plexapp.plugins.library.db
SQLite version 3.40.1 2022-12-28 14:03:47
146814
99206
If you’re using ZFS, there is a blocksize / record size for your filesystem.
You can use DBRepair to make the DB use that same recordsize
This will improve ZFS performance.
In the README file, I document the DBREPAIR_PAGESIZE variable.
Simply,
Get the recordsize for the dataset/filesystem
export DBREPAIR_PAGESIZE=xxxxxx (must be a power of 2 up to 65536)
Invoke DBRepair
“auto” optimize.
– It will optimize again – creating the new DB file with the given page size.
From the README –
[2024-01-14 17.25.48] Exporting current databases using timestamp: 2024-01-14_17.25.35
[2024-01-14 17.25.48] Exporting Main DB
[2024-01-14 17.25.59] Exporting Blobs DB
[2024-01-14 17.26.00] Successfully exported the main and blobs databases. Proceeding to import into new databases.
[2024-01-14 17.26.00] Importing Main DB.
[2024-01-14 17.26.00] Setting Plex SQLite page size (65536)
[2024-01-14 17.26.29] Importing Blobs DB.
[2024-01-14 17.26.29] Setting Plex SQLite page size (65536)
[2024-01-14 17.26.30] Successfully imported databases.
[2024-01-14 17.26.30] Verifying databases integrity after importing.
[2024-01-14 17.27.43] Verification complete. PMS main database is OK.
[2024-01-14 17.27.43] Verification complete. PMS blobs database is OK.
[2024-01-14 17.27.43] Saving current databases with '-BACKUP-2024-01-14_17.25.35'
[2024-01-14 17.27.43] Making repaired databases active
[2024-01-14 17.27.43] Repair complete. Please check your library settings and contents for completeness.
[2024-01-14 17.27.43] Recommend: Scan Files and Refresh all metadata for each library section.
These DBs now have a pagesize (record size) of 65536
