Plex for Samsung clock time wrong
Server Version#: 4.22.2
Player Version#: 4.21.2
Tuner Make/Model: Samsung UA75RU7100WXXY
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Live in Australia SA
When I turn on the clock, being daylight saving the time is out 1 hour, there is not way the tell plex that it is daylight saving as there is not options for it.
Regards
rodney
I believe the Plex app reads the time from your TV. Check your TV’s clock setting.
Yes, The time on the TV is correct and Plex is 1 hour different.
Can you provide screenshots showing the time in Plex and your TV’s clock?
Edit - Also, does your TV have a setting for daylight savings? I’m wondering if it adjusts the time internally only so the app uses the original time.
The Plex time is 1 hour behind the TV time, not sure screen shots will make any difference with this fact, but when the TV’s time is 7pm the time plex shows is 6pm. If you really want screen shots I’ll provide them.
Yes the TV is set to automatically set the time and DST.
So what I have gathered from other posts is that PLEX don’t read or care about problems people have with there products and getting bugs fixed will not happen.
Great way to run a software company.
Just to let everyone know that since sunday the time on the TV and on Plex are now the same.
Sunday was the end of DLS and our clocks went back 1 hour.
So until DLS starts again I have no problem.
Regards
Rodney
