Plex for Smart TV "Continue Watching" Auto advances
Hi All,
I am running the latest version on my LG55C7 and recently I noticed that if I do not move the cursor when I am on a “continue watching” item, it will auto advance to the next with some delay on it. When it reaches the end it returns. What happens when you try to select the last item, is that it often will jump to the “next” series before you get to select it - therefore selecting an episode or movie that is not the one you would like to watch.
I am generally not a fan of the feature, and I looked in the settings whether it can be turned off but cannot find it. Would it be possible to implement something like that if that is a feature or fix the bug if it is a bug.
