Plex Home Theater for Fedora
Here is some additional CentOS pledging.
I'd used Ubuntu for a long while, but wanted an OS at home that was closer to what I use at work (RHEL6).  I liked CentOS a lot better than Fedora because it seemed to be much more stable if a bit boring. Anyhow, I plan on sticking with CentOS and would like to be able to take advantage of Plex updates without needing to move to a different operating system.
Top
Top
Why not just install the RPM's then?
https://forums.plex.tv/topic/87230-the-plex-home-theater-rpms-thread-handing-out-builds-for-yall-pht-109180/?p=505574#entry505574
- Mark
I re-built my system over the weekend... starting out with a minimal install of CentOS 6.5...
I noticed that the i3 iGPU was struggling to cope with the brilliant image quality and sometimes skipped frames... I decided I deserve better... :)
Installed Xfce ONLY, removed nouveau and pulse audio, installed NVIDIA drivers downloaded from NVIDIA website (no kmod rubbish) and installed 1.0.12 PHT...
I moved away from the i3 2120 iGPU and installed an NVIDIA GTX 750 ti card...
Image quality is amazing, HD audio bitstream worked almost out of the box, (I only added alsa.conf) I am one seriously happy camper...
The HTPC has never been better...
hello my friends, I have some problems with the RPMs on centos 6.
info:
uname -a: Linux narf.troz.com 2.6.32-431.3.1.el6.x86_64 #1 SMP Fri Jan 3 21:39:27 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
release: CentOS release 6.5 (Final)
on ION platform.
xbmc runs perfectly, but I really like plex and I want to change to pmc.
when I run the pmc I get this:
$/usr/bin/env XBMC_HOME=/opt/plexhometheater/share/XBMC/ /opt/plexhometheater/bin/plexhometheater
/opt/plexhometheater/bin/plexhometheater: symbol lookup error: /opt/plexhometheater/bin/plexhometheater: undefined symbol: _ZNK12TiXmlElement18QueryBoolAttributeEPKcPb
I have run pmc without troubles on my fedora20, but in centos 6 I don't know why it isnt working
thank you.
EDIT: nevermind, I found the problem.
need to install tinyxml.x86_64 (this should be installed automaticly by the rpm dependency)
lets enjoy it!
