I tried to use the --reset command but it fails:
docker exec -it Plex-Media-Server /usr/lib/plexmediaserver/Plex\ Media\ Scanner --reset
terminate called after throwing an instance of 'boost::wrapexcept<boost::bad_lexical_cast>'
what(): bad lexical cast: source type value could not be interpreted as target
****** PLEX MEDIA SCANNER CRASHED, CRASH REPORT WRITTEN: /config/Library/Application Support/Plex Media Server/Crash Reports/1.19.4.2935-79e214ead/PLEX MEDIA SCANNER/4f6f81ea-8b61-49f4-2841c590-4178a67c.dmp
The returned Crash Report folder is empty:
