Plex Movie Requests
Hey Loken I think the app needs to have the plex.tv password login added, for example when you login with just the username and request a movie its then processed and reveals that was requested by the username so its easy for the next person to login using that same username and request movies under someone else username. Just my thoughts
You're talking about how you can see who has requested each movie? Only the administrator user can see who made each individual requests, your users can't see whose requested anything. If you open up  it in an incognito or different browser tab and just login to the user side, not the /admin site, you'll see usernames aren't shown.
Update for those that had requested a few features, currently available within the DEV channel, screenshots can be found here:
@jeradin has reworked the search form and now it provides search results as you type which is pretty sweet! Also, for any content you submit as of the current release, search results will show you if it's already been requested/downloaded in the search results line.
Requested items are now sort-able and paged (with custom sizing) as well as being searchable which is handy.
Still cleaning up SickRage/Beard support, and will start work on Sonarr next week (I'm moving houses this weekend) for those who use it.
Thanks Loken! :)
Can't wait for Sonarr! :D
Good luck with your house movement.
Very nice work guys. Just tested the dev version and looking good.
Is the TV requests supposed to be working with Sickbeard/rage yet? Currently get an error and shows this in my Sickrage log:
2015-04-22 01:27:46 WARNING TORNADO :: API :: Unable to find show with id 1554
Maybe have something to do with the search agents?
It was, I broke it by accident to enable a few other features. We know how to fix it, just haven’t pushed it up yet, should be up later tonight/tomorrow. I just finished adding links to search results and requests.
Just pushed the fix for that, let me know if it's still not working!
Just tried the new update and I can't seem to get it to run with my old database from the local folder says "exited with code 8" and won't boot.
Just did a 'git pull' and using the newest DEV branch it adds content to SICKRAGE.
It seems it overrides the default settings in sickrage for initial status wanted/skipped/archived/ignored.
Is it possible to have it use what is set as default in sickrage?
It's currently set to "wanted" on add yes, however there is a case to make it use the default settings. For a quick fix, in the /server/server.js file on line 272 you can remove the part at the end that says
 + "&status=wanted"
How did you update? Using Git would make it painless (git pull).
Some dependencies have been changed around and stuff recently. Do a clean install and then copy in your /.meteor/local folder in to the new installation and give it a try. It's often the .meteor folder that needs to get wiped (but NOT the local folder within it).
 + "&status=wanted"
I just didn't want multiple requests for complete TV Series all trying to download at once.
So I would prefer it default to "skipped' initially which would allow me to add them at a slower more balanced rate
Thanks for the quick response to the line of code, quickly fixed for now!
It makes sense, I'll probably switch it to default to be honest. But it's up for discussion right now.
That worked! Thanks Loken now only if i could get this to run on my shared web host.
Updated to now use the default SickRage setting: "Much like CP, we’ll take the default setting of SickRage regarding quality and downloading. People can edit things in SickRage to fit their taste". Someone just requested a bunch of TV shows and it overloaded my automated process for new shows because it wasn't added to the backlog process, so yeah I'm OK with switching it to default and for those that want they can tell SickRage to make all new episodes wanted instead of skipped.
Looks like latest version gave me a error on TV series request towards sickbeard, just shows as "error" when issuing the request, cannot find anything in the sickbeard logs.
Is the server outputting any error messages? I haven't had a chance to create a status page for SickRage yet unfortunately.
And the URL is the same as CP in regards to a trailing "/" at the end?
Just pushed a version to the DEV branch with a status page for SickRage/Beard, there's a link in Admin panel or at /sickrage. Let me know what it says!
It says "you have Sonarr, not SickRage fool!"  Just kidding. Can't wait for Sonarr support :)
Haha no worries! Yeah once I've moved I'll be spinning a VM up to install it to so I can get it working. Shouldn't be too difficult assuming it functions similarly to sickrage
