Plex Music Scanner to Detect iTunes Playlists
I would like to see the Plex Music Scanner have the ability to detect iTunes playlists. I use the Plex Music Scanner to create a section in my library that combines multiple iTunes libraries on the machine. It works well in understanding the metadata, however none of the playlists transfer over. The iTunes plugin only allows me to connect 1 library (the logged in user) to Plex, so this way I combine libraries from all user accounts on my machine. I have tried using the Plex iTunes Scanner but can never get it to work properly.
2022 clean-up: implemented (or used to be)
