Plex not listening to any port, connection refused on Apache2 (subdomain) [Solved]
what is your locale set for ? Something with the base OS installation / character set is not right.
again,
please do the removal and purge of the plex user as I instructed?
userdel plex
groupdel plex
rm -rf /var/lib/plexmediaserver
Now, so we can obtain better information about your installation, I would like you to use my Forum Beta installer from this thread. (this will be public release soon)
Latest version, which matches Plex Pass beta, is at the bottom.
Never had any problems with my locale before but here it is :
root@VALIS:~# locale
LANG=en_US.UTF-8
LANGUAGE=
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_IDENTIFICATION="en_US.UTF-8"
LC_ALL=
And I gave the beta version a try, it seems to install just fine :
root@VALIS:~# dpkg -i plexmediaserver_1.16.4.1484-6d5612c2f_amd64.deb
Selecting previously unselected package plexmediaserver.
(Reading database ... 197082 files and directories currently installed.)
Preparing to unpack plexmediaserver_1.16.4.1484-6d5612c2f_amd64.deb ...
PlexMediaServer installer: Pre-installation Validation.
PlexMediaServer installer: Pre-installation Validation complete.
Unpacking plexmediaserver (1.16.4.1484-6d5612c2f) ...
dpkg: warning: unable to delete old directory '/etc/init': Directory not empty
Setting up plexmediaserver (1.16.4.1484-6d5612c2f) ...
PlexMediaServer installer: Now installing based on:
PlexMediaServer installer:   Process Control:    Systemd
PlexMediaServer installer:   Plex User:          plex
PlexMediaServer installer:   Plex Group:         plex
PlexMediaServer installer:   Video Group:        video
PlexMediaServer installer:   Metadata Dir:       /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer installer:   Temp Directory:     /var/lib/plexmediaserver/tmp_transcoding
PlexMediaServer installer:   Lang Encoding:      en_US.UTF-8
PlexMediaServer installer:   HW transcoding:     Not found
PlexMediaServer installer: Completing final configuration.
Created symlink /etc/systemd/system/multi-user.target.wants/plexmediaserver.service â /lib/systemd/system/plexmediaserver.service.
PlexMediaServer installer: PlexMediaServer-1.16.4.1484-6d5612c2f - Installation successful.
Processing triggers for libc-bin (2.28-10) ...
Processing triggers for mime-support (3.62) ...
And now when I try to reach the webpage it spits PR_END_OF_FILE_ERROR at me. I’ll dig throught the logs later on. I’ve got to call it a day for now. Thanks again for the help. I’ll respond if I find anything interesting in the log. In the meantime please keep shooting ideas at me if you got any.
When you next attempt, attempt using an incognito window in FireFox.
incognito mode isn’t helping (and I ususally refresh page with ctrl+f5 to delete cookies).
Still a PR_END_OF_FILE_ERROR
I don’t know where or how to proceed. Somehow the SSL sequence is corrupt and you are getting SSL errors. I can only surmise you’ve compromized something deep in the SSL/TLS layering.
This might be a good time to reinstall the entire OS fresh and leave the Apache out until after everything works as a basic system.
If you wish to continue, did you check https://www.wowza.com/community/questions/7506/ssl-error-pr-end-of-file-error.html
Well I just tried to login from work and the webpage is up … Probably firefox’s cache got messed up at home (even in incognito ? weird).
Anyways the plex webpage is up and still “looking for servers”.
two ways to do this on your home lan but
  1. If RFC-1918 compliant, you open the IP addr of the host in browser
    -or-
If not RFC-1918 LAN or host is not on the same subnet (remote hosts count as this condition)
  • SSH-tunnel to it using ssh -L 8888:127.0.0.1:32400 ip.addr.of.host ,
  • sign in, let sit idle,
  • open http://127.0.0.1:8888/web in your local incognito window
And it’s working !
Not sure why my network is not RFC-1918 compliant thought … My server is hosted by http://online.net it’s a fixed IP and everything. I had to take the second route.
But anyways it’s finally working ! I’ll rewire vhosts later today, it shouldn’t be that hard now that everything works fine.
Anways I’ll give plex a week or so and except if I encounter any major hiccups I’ll probably get a life pass so I can set things properly for my family and friends. Thanks again @ChuckPa . I’m not sure what answer to select as “Solution”, so I’ll pick the last one for now and will probably edit a sum-up once in my first post for others later (after the vhosts shenanigans).
This topic was automatically closed after 90 days. New replies are no longer allowed.
