I noticed that Plex Notify is not picking up the height of the resolution and at times the audio or video codecs in the Statistics page. Any idea why these are being overlooked?
ahem, I just got hammered with endless notifications via Pushover that there is an update update to plex notify, had to force close. And I can't seem to RDP home, probably the proccess kills my CPU...
Primary settings works fine now on second Plex Notify
I really think those settings should be disabled on "non primary" or centralized if "non primary" would be able to change them (maybe make it an option...)
***Yes, about the update crazy notification loop, I also have this bug.
Also, I would personally like to disable the "animation" when opening a Plex notify screen. Not a big fan generally and not really well suited when managing in RDP.
Not a big deal though.
If you are RDP'ing from a windows machine you can just have plex notify on it =)
Request: It would be nice to see the season and episode number added to a show's title throughout Plex Notify. I find myself having to go to Plex/Web for this information. Is this possible?
Hey thanks for all your hard work on this! I can't seem to get it to install though, I wonder if I'm missing something? I get the following error every time I run the clickonce installer: "Cannot Start Application. Cannot Continue. The application is improperly formatted. Contact the application vendor for assistance." I've attached the error log if that helps...
