Fixed.
Alpha v0.0.0.46- Plex Notify will now get Video Images from PMS before TMDB
Plex Notify is pulling thumbnails instead of poster art. Keep in mind that I customize images for poster art and that is the reason I'd like to have PN scrape the PMS.
Poster Art for "24 Hours to Kill" in PMS:
Showing thumbnail of "24 Hours to Kill" in PN.
oops! lol I'll fix this haha
Ok it looks like I got everyone's requests in order and the major bugs flushed out. I'm going to let this sit til tomorrow night, if there's any more bugs let me know. Im going to finish up the webserver integration and RSS. Hopefully this weekend we have a web portal of some kind going.
I am still seeing thumbnails instead of poster art for TV Shows. Would a log help?
Humm sure. I am getting the images ok.
Sent from my SM-N900P using Tapatalk
This was working perfectly before switching to the TVDB. It does not seem to be taking the main poster image from PMS.
Are you on .49?
Yes.
Yes.
Clear your cache and load stats again
If you mean clear my Chrome Browser cache, I have done that with the same results.
No, close statistics, open settings, click on advanced and click clear image cache
That did the trick. Now I will know what to do if this issue arises again. Thanks.
Is anybody else having issues with the auto update?
Since the last few revisions my autoupdate stopped working, if I manually press the check for update button I now see the popup box (show beneath the active window) advising an update is available. When I select to update I rceive a PN has stopped working error and it crashes out, upon reloading the app the auto-update then kicks in and I have to install!
Strange, this has happened about 4 times now
OK here are my results for V0.0.0.49
1) Auto update still isn't working. I get a notify saying it's been done but it hasn't. I have to stop and manually update.
2) My SQL errors have now been fixed.
3) I never see a Plex Notify playing/stopped/started/paused message or statistic for a video that is direct played. I only see videos in Plex Notify that have some form of transcode. I do see direct play videos in the 'Now Playing' tab of Plex/Web.
4) The culture settings seem to work so I now get UK date stamps but the pull down forgets what you've set it to. It's blank.
5). On my Surface 2 I miss stop/stop-resume events. I see paused/pause-resume. I think this is a Surface 2 Plex App issue as Plex/Web still thinks I'm playing a video when I am not. The Windows app player interface doesn't have a stop button which may have something to do with it. Closing the app doesn't have any effect either; the Plex/Web still thinks I'm playing it. Garbage in - Garbage out.
I've now gotten some new problems that no simple re-install will fix (tested).
I recently noticed that no new notifications are shown, and the statistics page has a last entry from two days ago.
And that last entry as well as the one preceding it show entirely wrong timestamps set six hours later than the true time when those playback events occurred.
Checking the log file I found several of those "Object reference not set to an instance of an object." error cases which flooded the logs the last time I had serious problems, so I assume that the database took some damage at that time, which were not entirely fixed by the re-install even though it seemed to work for a while.
I'm now going to uninstall 'Plex Notify' again, and this time also delete its database, so that it will be forced to rebuild everything from scratch after the next re-install.
Fortunately the existing statistics are of no long-term importance to me, so I'm not really losing anything, and its the easiest way to ensure a clean restart.
----- after re-installing -----
Everything is back to normal again, now on version .49
Best regards: dlanor
No Europe time like 18-02-2014 12:00:00, shows 2/18/2014 12:00:00 PM, have choosen Danish in Culture
If i start a movie from start, first time (0%) shows "BearPlex id watching Hours", if i start the movie from start (0%) again no "is watching Hours"
"Only show last event = Off in Statistics", please make dobbel click on "Open" instead of one click to open "Statistics"
Clean Install on Clean DB (Deleted before install)
