Alpha v0.0.0.79- Fixed update.- Plugin settings now properly save.If you are still having trouble updating try this:Open the Command prompt, (Start -> run -> type "cmd" (without the quotes) and hit enter.)run or copy/paste this into the command prompt:rundll32 %windir%\system32\dfshim.dll CleanOnlineAppCacheAlso you can try going to:C:\Users\*YOUR USER*\AppData\Local\Apps\2.0\*RANDOM LETTERS*\*RANDOM LETTERS*All the versions of plex notify will be in this directory. (up to 5 versions back I think) Sort the folder by datetime and keep the newest one and delete all the older once that are prefixed with plex.. Alternatively you can uninstall Plex Notify and delete all of them and reinstall. You will not lose any data!!!! all data is stored in c:\ProgramData\Plex Notify.
Thanks for the tip. Unfortunately this didn't work for me. Ended up deleting all the previous Plex Notify versions and clearing the online app cache and still get an error when attempting to install.
ERROR DETAILS Following errors were detected during this operation. * [5/20/2014 6:06:28 PM] System.ArgumentException - Value does not fall within the expected range. - Source: System.Deployment - Stack trace: at System.Deployment.Internal.Isolation.IStore.LockApplicationPath(UInt32 Flags, IDefinitionAppId ApId, IntPtr& Cookie) at System.Deployment.Application.ComponentStore.LockApplicationPath(DefinitionAppId definitionAppId) at System.Deployment.Application.SubscriptionStore.LockApplicationPath(DefinitionAppId definitionAppId) at System.Deployment.Application.FileDownloader.PatchFiles(SubscriptionState subState) at System.Deployment.Application.FileDownloader.Download(SubscriptionState subState) at System.Deployment.Application.DownloadManager.DownloadDependencies(SubscriptionState subState, AssemblyManifest deployManifest, AssemblyManifest appManifest, Uri sourceUriBase, String targetDirectory, String group, IDownloadNotification notification, DownloadOptions options) at System.Deployment.Application.ApplicationActivator.DownloadApplication(SubscriptionState subState, ActivationDescription actDesc, Int64 transactionId, TempDirectory& downloadTemp) at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc) at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl) at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
