I get an error when trying to start the webserver:
In the gui:
The system cannot find the path specified.
For more information about the error, run iisexpress with the tracing switch enabled (/trace:error).
And the logs:
0.0.0.81
Object reference not set to an instance of an object.
at PlexNotify.DatabaseHelper.StoreMediaContainer(MediaContainer mc) in c:\Users\James\Source\Workspaces\PlexNotify\PlexNotify\Database\DatabaseHelper.cs:line 350
at PlexNotify.MainWindow.BW_DoWork(Object sender, DoWorkEventArgs e) in c:\Users\James\Source\Workspaces\PlexNotify\PlexNotify\MainWindow.xaml.cs:line 224
Note the directory structure is looking for /James/ ...
In the gui:
And the logs:
0.0.0.81
Rock Star amazing work ! are you planning to have also statistics over web ?
I am making a web API and a Plugins landing page so users can make a web stats through plugins. It would be a huge learning curve for me as I am a desktop developer.
I return with my idea of home automation integration :)
I just tested a joint base IFTTT but the period of execution of IFTTT routines can be considered in a home automation solution.
Example: When I start a movie and it is dark when the lights go out. If I put the movie paused then it comes back, etc..
To do this I just have to make an http request to a sensor box my home automation.
It should therefore be a field somewhere to just add this request but for a specific user.
Do you think this can be possible?
Thank you for your reply.
Don't bother with IFTTT that would be extremely slow in comparison to Eventghost. You can use the growl plugin and it would be immediate, not having to wait for a message to propagate the internet.
Alpha v0.0.0.81 New Users screen. Remote desktop friendly and easier to use!
I've noticed one problem with this new 'Users' screen, in that it ignores existing user images, as used in notifications. Those images are not displayed in the new 'Users' screen, showing only the gray generic outline image for every user, even though the previously defined images are still used in notifications and event logs.
The log rotation at 10KB does not seem to be working at all for me. (Like ‘liiight’ previously reported for his log.) Mine’s a bit smaller than his, at just 1519 KB, but that’s still a lot more than the supposed 10 KB limit…
There’s no trace whatever that the log file ever has been ‘rotated’. The “C:\ProgramData\Plex Notify\Logs” folder only contains the single file “PlexNotify.log.xml” of 1519 KB. This appears to include log events dating back to early March, which is probably when I last did a full uninstall+reinstall.
I also question some contents of that log file, which has numerous references to a nonexistent OS user folder. (“c:\Users\James\Source\Workspaces\PlexNotify\VARIOUS_FILE_NAMES”)
I think that may be the original location of your source code for app parts involved in the logged events.
I understand the usefulness of having debug logs specifying affected source files and even line numbers, as seems to have been added to the logging recently. It seems to have started in v0.0.0.79, as my older log entries don’t use such path/file specifications.
But I suggest that you trim off the full path string, reducing it to just the local subfolder and file names as used within your PlexNotify source folder. This would remove redundant bulk from the logs, as numerous repetitions of that “c:\Users\James\Source\Workspaces\PlexNotify” substring are pointless.
The log rotation at 10KB does not seem to be working at all for me. (Like 'liiight' previously reported for his log.)
Mine's a bit smaller than his, at just 1519 KB, but that's still a lot more than the supposed 10 KB limit...
There's no trace whatever that the log file ever has been 'rotated'.
The "C:\ProgramData\Plex Notify\Logs" folder only contains the single file "PlexNotify.log.xml" of 1519 KB.
("c:\Users\James\Source\Workspaces\PlexNotify\VARIOUS_FILE_NAMES")
I understand the usefulness of having debug logs specifying affected source files and even line numbers, as seems to have been added to the logging recently. It seems to have started in v0.0.0.79, as my older log entries don't use such path/file specifications.
But I suggest that you trim off the full path string, reducing it to just the local subfolder and file names as used within your PlexNotify source folder. This would remove redundant bulk from the logs, as numerous repetitions of that "c:\Users\James\Source\Workspaces\PlexNotify\" substring are pointless.
Best regards: dlanor
Thanks for the report. I fixed the logging bug, it will be in the next patch.
