Without any other updates, the transition from .107 to alpha .111 now fails to start plex notify. I've tried deleting the programdata\Plex Notify folder and I still get the same error.
I've confirmed that I have .net 4.5.2 installed via the registry and Sql Server CE is also installed.
How do I transition from the old version to this new one?
The release of beta 1 will be on december 25th. This is a dev release. It allows any developers to create programs using the api, so their programs can be ready at the launch of Beta 1.
i have windows 2008 and get this error. How can I unistall it?
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: plex notify.exe
Problem Signature 02: 1.0.0.0
Problem Signature 03: 54278343
Problem Signature 04: System.Data.SqlServerCe
Problem Signature 05: 4.0.8876.1
Problem Signature 06: 4fcd17f1
Problem Signature 07: 401
Problem Signature 08: 0
Problem Signature 09: System.Data.SqlServerCe.SqlCe
OS Version: 6.1.7601.2.1.0.272.7
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882
Problem signature:
Locale ID: 1033
That worked but now when I try to click in setting give me this error
Problem signature:
Problem Signature 04: mscorlib
Problem Signature 05: 4.0.30319.18444
Problem Signature 06: 52717edc
Problem Signature 07: 3e69
Problem Signature 09: PSZQOADHX1U5ZAHBHOHGHLDGIY4QIXHX
Locale ID: 1033
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Anyone not have a plexpass account and has the latest PMS 0.9.11.4 Check if you can use Plex Notify. I think they changed the latest version to not require plexpass for accessing their now playing API.
If someone could check that for me it would be great.
I'm trying to set the plex.tv login on the latest build, but it returns the following error in the log:
Attempting to authenticate to MyPlex with User name rogueosb.
There is an error in XML document (2, 34).
at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
at System.Xml.Serialization.XmlSerializer.Deserialize(Stream stream)
at PlexNotify.Shared.APIs.WebAPI.GetPage[T](String url, HTTPRequestType requestType, Dictionary`2 parametersDictionary, Dictionary`2 headersDictionary, String username, String password) in e:\WinDev\PlexNotify\PlexNotify.Shared\APIs\WebAPI.cs:line 66
Line Number: 28; There is an error in XML document (2, 34).
Line Number: 29 at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
Line Number: 28; Value was either too large or too small for a UInt16.
Line Number: 29 at System.UInt16.Parse(String s, NumberStyles style, NumberFormatInfo info)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderPlexUser.Read9_PlexUser(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderPlexUser.Read10_user()
Authenticate to MyPlex with User name rogueosb failed.
Object reference not set to an instance of an object.
at PlexNotify.Shared.APIs.PlexMediaServer.GetSessions() in e:\WinDev\PlexNotify\PlexNotify.Shared\APIs\PlexMediaServer.cs:line 25
at PlexNotify.Service.PnService.UpdateTimer_Elapsed(Object sender, ElapsedEventArgs e) in e:\WinDev\PlexNotify\PlexNotifyService\PlexNotifyService\PNService.cs:line 113
Line Number: 28; Object reference not set to an instance of an object.
Line Number: 29 at PlexNotify.Shared.APIs.PlexMediaServer.GetSessions() in e:\WinDev\PlexNotify\PlexNotify.Shared\APIs\PlexMediaServer.cs:line 25
I have PlexPass and have enabled Plex Home in the latest version (authorization on local networks is required). I have tried with both my username and my email; same error. The alpha version works just fine.
EDIT: Using the default string provided in the postman collection gives works, as it gives an Unauthorized error rather than XML error.
EDIT2: Tried an incorrect password for my account, also gives Unauthorized error, so maybe it's the reply from the server?
Thanks for the info, I will include more logging info in tonight's build to get the XML that it can't deserialize.
