Plex on DS118 crash
Hello,
My plex server on my synology ds118 often crashes. I noticed that this is every time I connect from my TV.
I uninstall, reinstall, restart my nas, did all the latest updates but it still doesn’t work.
Do you have a solution?
thanks a lot for your help
Server Version#: DSM 6.2.3-25426 Update 3
Player Version#: 1.21.1.3876-3c3adfcb4
Plex Media Server Logs_2021-01-17_19-03-07.zip (740.6 KB)
Thank you very much for your quick response!
Thank you for filebot,I used to do it with automator on mac. but I couldn’t find anything for synology and windows. Thanks a lot, I’ll rename the files and see if that works.
It is not really a crash I think, rather the server which stops and it must be restarted.
Thank you very much
Does Plex know there is this problem? Me and a friend have this problem
