Plex OpenVPN IP Route Bypass
Server Version#: 1.15.8.1198
trying to set up OpenVPN Client
added ip route in Toronto.conf
route plex.tv 255.255.255.255 net_gateway
external ip for Plex changed from vpn to Local
It says accessible to outside for about 20 seconds then goes back to not available
Any ideas as to what else I have to do to make it work?
look at time code 14:17:53.602 the 192.168.18.38 i don’t know what that is the servers static ip is 192.168.18.10
Jun 15, 2019 14:17:52.870 [0x7ff8c5115700] DEBUG - NAT: UPnP, found device <http://192.168.18.1:1780/InternetGatewayDevice.xml> with private address <192.168.18.10>
Jun 15, 2019 14:17:52.871 [0x7ff8c5115700] DEBUG - NAT: UPnP, usable device <http://192.168.18.1:1780/InternetGatewayDevice.xml> with private address <192.168.18.10>.
Jun 15, 2019 14:17:52.872 [0x7ff8c5115700] DEBUG - NAT: UPnP, public address is ***.***.***.***
Jun 15, 2019 14:17:52.873 [0x7ff8c5115700] DEBUG - MyPlex: Sending Server Info to myPlex (user=, ip=, port=16492)
Jun 15, 2019 14:17:52.874 [0x7ff8c5115700] DEBUG - HTTP requesting POST https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx&async=1&asyncIdentifier=3243e82a-73ed-4e04-8ddf-01e435b5880e
Jun 15, 2019 14:17:52.882 [0x7ff8737fe700] DEBUG - Sync: updating status for sync list 33733060, sync item 35527839, generator 5041
Jun 15, 2019 14:17:52.991 [0x7ff8737fe700] DEBUG - Sync: updating status for sync list 33733060, sync item 35527858, generator 5042
Jun 15, 2019 14:17:53.078 [0x7ff8737fe700] DEBUG - Sync: updating status for sync list 33733060, sync item 35527928, generator 5043
Jun 15, 2019 14:17:53.173 [0x7ff8737fe700] DEBUG - Sync: updating status for sync list 33733060, sync item 35528112, generator 5044
Jun 15, 2019 14:17:53.272 [0x7ff8737fe700] DEBUG - Sync: updating status for sync list 33733060, sync item 35528123, generator 5045
Jun 15, 2019 14:17:53.367 [0x7ff8737fe700] DEBUG - Sync: updating status for sync list 33733060, sync item 35528134, generator 5046
Jun 15, 2019 14:17:53.414 [0x7ff892ffd700] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/release_channels?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jun 15, 2019 14:17:53.415 [0x7ff892ffd700] DEBUG - EventSource: Resolving 172.105.97.53 port 443
Jun 15, 2019 14:17:53.415 [0x7ff8c5916700] DEBUG - EventSource: Resolved 172.105.97.53 to 172.105.97.53
Jun 15, 2019 14:17:53.416 [0x7ff892ffd700] DEBUG - MyPlex: Updating device connections (from timer: 0)
Jun 15, 2019 14:17:53.416 [0x7ff892ffd700] DEBUG - HTTP requesting PUT https://plex.tv/devices/f33241fbbc2eaa25636755a6f26060242773512a?Connection[][uri]=http://192.168.18.10:32400&httpsEnabled=1&httpsRequired=0&dnsRebindingProtection=0&X-P$
Jun 15, 2019 14:17:53.419 [0x7ff8b57fa700] DEBUG - HTTP 200 response from GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jun 15, 2019 14:17:53.420 [0x7ff8c6117700] DEBUG - Auth: authenticated user 1 as user
Jun 15, 2019 14:17:53.420 [0x7ff871ffb700] DEBUG - Request: [192.168.18.38:54484 (Subnet)] PUT /myplex/refreshReachability (9 live) GZIP Signed-in Token (user)
Jun 15, 2019 14:17:53.451 [0x7ff8b77fe700] DEBUG - HTTP 200 response from GET https://plex.tv/api/resources.xml?includeHttps=1&includeRelay=1&auth_token=xxxxxxxxxxxxxxxxxxxx
Jun 15, 2019 14:17:53.451 [0x7ff8b77fe700] DEBUG - Media Server: Tested all servers in 0.0 seconds.
Jun 15, 2019 14:17:53.459 [0x7ff8737fe700] DEBUG - Sync: updating status for sync list 33733060, sync item 35528150, generator 5047
Jun 15, 2019 14:17:53.514 [0x7ff8c5916700] DEBUG - EventSource: Connected in 66 ms.
Jun 15, 2019 14:17:53.514 [0x7ff8c5916700] DEBUG - EventSource: Wrote data, reading reply.
Jun 15, 2019 14:17:53.547 [0x7ff8737fe700] DEBUG - Sync: updating status for sync list 33733060, sync item 35528159, generator 5048
Jun 15, 2019 14:17:53.597 [0x7ff8c5115700] DEBUG - HTTP 201 response from POST https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx&async=1&asyncIdentifier=3243e82a-73ed-4e04-8ddf-01e435b5880e
Jun 15, 2019 14:17:53.597 [0x7ff8c5115700] DEBUG - MyPlex: Published Mapping State response was 201
Jun 15, 2019 14:17:53.597 [0x7ff8c5115700] DEBUG - MyPlex: Got response for f33241fbbc2eaa25636755a6f26060242773512a ~ registered 99.253.121.133:16492
Jun 15, 2019 14:17:53.599 [0x7ff850ff9700] DEBUG - MyPlex: Sending Server Info to myPlex (user=user, ip=, port=16492)
Jun 15, 2019 14:17:53.599 [0x7ff850ff9700] DEBUG - HTTP requesting POST https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx&async=1&asyncIdentifier=fe156c30-6492-491b-acde-74ad4cc6c0d5
Jun 15, 2019 14:17:53.601 [0x7ff8c5916700] DEBUG - Auth: authenticated user 1 as user
Jun 15, 2019 14:17:53.602 [0x7ff8717fa700] DEBUG - Request: [192.168.18.38:54467 (Subnet)] PUT /myplex/refreshReachability (8 live) GZIP Signed-in Token (user)
Jun 15, 2019 14:17:53.633 [0x7ff8737fe700] DEBUG - Sync: updating status for sync list 33733060, sync item 35528310, generator 5049
Jun 15, 2019 14:17:53.660 [0x7ff8b67fc700] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/server/webhooks?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jun 15, 2019 14:17:53.725 [0x7ff8737fe700] DEBUG - Sync: updating status for sync list 33733060, sync item 35892602, generator 5137
Jun 15, 2019 14:17:53.812 [0x7ff8737fe700] DEBUG - Sync: updating status for sync list 33733060, sync item 35892609, generator 5138
Jun 15, 2019 14:17:53.896 [0x7ff8737fe700] DEBUG - Sync: updating status for sync list 33733060, sync item 36048393, generator 5160
Jun 15, 2019 14:17:53.928 [0x7ff8c5916700] DEBUG - EventSource: Read HTTP reply header.
Jun 15, 2019 14:17:53.929 [0x7ff8c5916700] DEBUG - MyPlex: We appear to have regained Internet connectivity.
Jun 15, 2019 14:17:54.040 [0x7ff8c5916700] DEBUG - PublicAddressManager: Obtaining public address and mapping port.
Jun 15, 2019 14:17:54.040 [0x7ff8c5916700] DEBUG - EventSource: Successfully connected to 172.105.97.53.
Jun 15, 2019 14:17:54.040 [0x7ff8b77fe700] DEBUG - PublicAddressManager: Obtaining public IP.
Jun 15, 2019 14:17:54.040 [0x7ff8b77fe700] DEBUG - HTTP requesting GET http://plex.tv/pms/:/ip
Jun 15, 2019 14:17:54.113 [0x7ff892ffd700] DEBUG - HTTP 200 response from PUT https://plex.tv/devices/f33241fbbc2eaa25636755a6f26060242773512a?Connection[][uri]=http://192.168.18.10:32400&httpsEnabled=1&httpsRequired=0&dnsRebindingProtectio$
Jun 15, 2019 14:17:54.113 [0x7ff8c5115700] DEBUG - MyPlex: Last published value didn't change, we're done.
Jun 15, 2019 14:17:54.116 [0x7ff892ffd700] DEBUG - CERT: Certificate will not expire soon.
Jun 15, 2019 14:17:54.300 [0x7ff850ff9700] DEBUG - HTTP 201 response from POST https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx&async=1&asyncIdentifier=fe156c30-6492-491b-acde-74ad4cc6c0d5
Jun 15, 2019 14:17:54.300 [0x7ff850ff9700] DEBUG - MyPlex: Published Mapping State response was 201
Jun 15, 2019 14:17:54.300 [0x7ff850ff9700] DEBUG - MyPlex: Got response for f33241fbbc2eaa25636755a6f26060242773512a ~ registered ***.***.***.***:16492
Jun 15, 2019 14:17:54.300 [0x7ff871ffb700] DEBUG - MyPlex: we already have requested a connectivity refresh for async identifier fe156c30-6492-491b-acde-74ad4cc6c0d5 which has not yet expired.
That works for me using PIA vpn. Should be similar for you.
