Plex pick up 1 tuner only - help!
Thanks,
I have PM’d you back, if you could take a look that would be great!
Hi
I sent you a couple of messages but not had a reply for a week or so, could you have a look and update me please re 2 tuners and xml.
Not sure if you replied as I had msg saying my emails are being bounced but my associated email address is correct!
Sorry I hadn’t replied yet. I got swamped last week and I’m on vacation this week. Are you saying that the tuners are detecting different channels when doing a channel scan? Are they hooked up to the same antenna?
Both tuners connected to same powered antenna.
Tuner 1 - 165 channels—138 enabled
Tuner 2 - 177 channels—124 enabled
I have made sure when first adding the tuners, I use all the relevant settings on 2nd tuner too
Thanks for your help
Hi, looks like I’m trying to set up exactly the same thing as you! Is this update a general one which I can access too so I can get both tuners working as well?
Thanks!
hi you would need to asl for specific build
Ah ok thanks! @timwoj how would I go about requesting a specific build?
I can forward it to you.
That’s super-odd. Can you do me a favor and do a channel scan on both of them and send me the Plex Tuner Service log? I’m curious why it would find different channels unless you just got a blip in signal strength from some of them that caused it to miss some.
Will do but how do i get tuner service log?
I have a Technisat Combo HD CI tuner on Windows (single device, 2 tuners), with BDA driver and I have the same issue. This tuner has a DVB-T and a DVB-C tuner, but Plex only Pick Up the DVB-T one, which is bad, since I want to use dvb-c.
Here is the device discover:
<MediaContainer size="2">
<Device key="dvb%23bda%230%23%40device%3apnp%3a%5c%5c%3f%5cusb%23vid_14f7%26pid_0003%230008c9d908b1%23%7b71985f48-1ca1-11d3-9cc8-00c04f7971e0%7d%5c%7ba0f9219e-7c58-4a1d-b8e7-7325f0bc4501%7d" title="DTV-DVB BDA DVBT Tuner" status="alive" protocol="livetv"uuid="device://tv.plex.grabbers.tunerservice/dvb%23bda%23usb%23vid_14f7%26pid_0003%230008c9d908b1%23" interface="usb" vendorIdentifier="14f7" productIdentifier="0003" tuners="1"/>
<Device key="dvb%23bda%230%23%40device%3apnp%3a%5c%5c%3f%5cusb%23vid_14f7%26pid_0003%230008c9d908b1%23%7b71985f48-1ca1-11d3-9cc8-00c04f7971e0%7d%5c%7bfc65e31b-ae38-4a01-8ea8-43c5e794b67e%7d" title="DTV-DVB BDA DVBC Tuner" status="alive" protocol="livetv"uuid="device://tv.plex.grabbers.tunerservice/dvb%23bda%23usb%23vid_14f7%26pid_0003%230008c9d908b1%23" interface="usb" vendorIdentifier="14f7" productIdentifier="0003" tuners="1"/>
</MediaContainer>
And I opened another question here:
Can anyone help me?
Both tuner works fine in both TVMosaic and MediaPortal.
