Was there ever a “part 2”?
This may be a noob question, but does anyone know the proper syntax to issue an URL command from within a Plex Agent Plugin. The only documentation I found was here. This works fine when running directly in a browser (with token hardcoded for time being), but as stated, I would like to execute such a command from a Agent Plugin.
Secondary followup question: As called from “within” Plex, does this require token code auth? If so, how could one query the current token and servername out of the plugin?
Thanks in advance for any hints.
Good job! Very informative.
I often use this tool to validate JSON: JSON Formatter
It’s simple to use and quite functional
Is there a posting like this that is a little more recent? Many of the links in the original walkthrough are dead and makes it hard to learn from this.
Sadly not, AFAIK
