Hello fellow Plexians, I need your advice please on how i should setup my new upgrade from a Synology ds1815+ to a way beefier Qnap TS-1277. Yay! No more random stutters and more space
My usecase:
- I want a setup and forget setup. Plex / Sonarr / Radarr / Jackett / NZBGet / Deluge/
- Flawless and fast Plex experience, quick download and unpack.
- I have 1 nvidia shield, 1 hacked cromebook & 4K TVs - no users outside home.
- Just 1GbE Cat 6 inhouse. 1000/1000 Mbit internet.
Hardware 1:
- QNAP TS-1277-1700-16G High-Performance 12 Bay (8+4) -
- 1 x WD CSSD Red 500GB 2.5 SATA (WDS500G1R0B)
- 4 x Western Digital Red WD100EFAX 10TB (will buy more later on)
Hardware 2:
- Synology ds1815+
- 8 x Western Digital Red 4TB
What i need help figuring out is how to utilize SSD slots on QNAP for PMS and does it make any sense for my use case?
Fresh install of QTS to SSD (and buy one more for mirroring. IĀ“d get faster PMS and QTS performance, but iād be stuck to only download files of up to about 400GB, since my SSD is only 500 GB. Main arry is then installed, for cold storage. With less wear and tear on my expensive 10TB drives.
I could use Qtier on QTS 4.3.6, and make one volume for ssd and hdd, but trawling forum posts people donāt seem too thrilled about it. Then again my use case is quite different from most use cases i see on these high end NAS models.
I could use SSD as a cache disk?
Just drop the SSD/m2 route.
Lastly iām not quite sure if i should just use QTS packages of Plex / Sonarr / Radarr / Jackett / NZBGet / Deluge/ OR if i should do go the Docker route which seems like all the rage. For me it looks complex and not a setup and forget setup.
Q. If someone has a setup and forget Docker setup please point me in the right direction.
