Plex serve stopped working and cannot revive:._StoredValues missings
Server Version#: 1.41.3.9314-a0bfb8370
Player Version#: doesn’t mater
This morning I woke up to a dying plex server: Happy New Year.
The container was still running, opening a client would result in a weird state where all the media’s assets were gone, some media were playable, but not most of them.
I killed the container and launched a new one, and since then the plex server hasn’t come up :frowning:
Checking the container’s logs I get:
Starting Plex Media Server. . . (you can ignore the libusb_init error)
Connection to localhost (::1) 32400 port [tcp/*] succeeded!
[ls.io-init] done.
Traceback (most recent call last):
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a0bfb8370/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py", line 168, in <module>
    run()
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a0bfb8370/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py", line 148, in run
    core = Framework.core.FrameworkCore(bundle_path, FRAMEWORK_DIR, config)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a0bfb8370/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/core.py", line 148, in __init__
    self.set_value('LastVersion', self.version)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a0bfb8370/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/core.py", line 551, in set_value
    self.storage.save(self._values_file_path, json_str)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a0bfb8370/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/storage.py", line 81, in save
    f = open(tempfile, mode)
IOError: [Errno 2] No such file or directory: '/config/Library/Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.system/._StoredValues'
So I went looking for the missing files, and I found the following situation:
  • most directories under Plex Media Server/Plug-in Support/Datawere gone, and those left were pretty much empty
  • Plex Media Server/Media and Plex Media Server/Metadatawere gone
I restored the missing stuff from a backup, admittedly a couple of months old.
Started the server again, and now the logs are full of:
Exception in thread ensure_agent_info_exists_inner:
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/threading.py", line 801, in __bootstrap_inner
    self.run()
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/threading.py", line 754, in run
    self.__target(*self.__args, **self.__kwargs)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a0bfb8370/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/runtime.py", line 1123, in _start_thread
    sandbox.context.import_values(context_values)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a0bfb8370/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/code/context.py", line 66, in import_values
    setattr(self, key, value)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a0bfb8370/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/code/context.py", line 187, in cache_time
    self._cache_time = self._core.networking.cache_time
AttributeError: 'FrameworkCore' object has no attribute 'networking'
    self.run()
    self.run()
    self.run()
    self.run()
    self.run()
    self.run()
    self.run()
    self.run()
    self.run()
    self.run()
    self.run()
Critical: libusb_init failed
Exception in thread Thread-1:
    self.run()
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/threading.py", line 1072, in run
    self.function(*self.args, **self.kwargs)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a0bfb8370/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/runtime.py", line 1158, in _start_timed_thread
    self._start_thread(f, args, kwargs, sandbox, context_values)
The server is inaccessible to clients, if I access it directly via a browser on port 32400 I get the starting page of the setup process, clicking the " got it" button it just hangs on Please wait a moment while Plex starts. until it just suggests to come to the forum and ask here presenting logs.
and here are the logs:
Logs.tar (460 KB)
If I click on name or media library I can still see my stuff:
Yet nothing is working, and after pretty much wasting my 1st day of 2025 (it’s 5pm now :laughing:) on this I’m at a loss :face_with_spiral_eyes:
I just wanted to nurse my hangover on the couch watching some stuff, rather than fighting (and losing) with this thing :sob:
PS: I couldn’t help but notice a frightening python27, a 10-year-old version not supported anymore since 2020, in my logs. Please tell me you’re not really still using that thing?
UP
sorry but I need to bump this up as my Plex server is still down, I’ve no idea how to fix it, and this post is sliding into oblivion :frowning:
If I’ve to start from scratch, considering the effort it takes to reimport 10T of content, I’ll just switch to Jellyfin.
