Hi all,
I’ve put together a small open‑source project to automate subtitles around Plex using existing tools:
Bazarr for “normal” subtitle downloads
OpenAI Whisper + GPT to generate subtitles when nothing is available (e.g., ja.srt + .en.srt)
ffsubsync to keep .en.srt aligned whenever new/changed subs appear
It’s packaged as a Docker Compose stack with:
Custom images for a long‑running subsync watcher
An on‑demand whisper-runner container you trigger per file (or hook into your own automation)
A sample .env.example and README that explain paths, env vars, and Bazarr configuration
Project page:
https://github.com/lems111/plex-subtitle-orchestrator
I’d love feedback from other Plex/self‑hosters:
Does this overlap with how you’re handling subtitles today?
Any issues you foresee with this Bazarr + Whisper + ffsubsync combination?
Ideas for improvements (e.g., better defaults, language presets, integration with existing automation)?
Thanks in advance for any comments or suggestions.
