Plex Sync Transcoding entire HEVC H265 due to missing "audio profile"?
Hi guys,
I’ve been trying real hard to get Plex to stop transcoding my crap while sync’ing on my iPad Pro 2021 as it can literally just read anything (VLC / Infuse can, so why not Plex?). Obviously, when I play the media directly on my iPad via the Plex App, I can clearly see that Plex only transcodes the audio, not the video.
Looking at the logs, it seems that it complains about not being able to read “audio.profile”, states “no remuxable profile found” and then just goes around and transcodes both video and audio…
The one discrepancy I notice between the MediaInfo and the Profile (see below) is that the media’s audio is 6 channels, whereas the profile only allows 2 channels - I’d assume that the Audio can be transcoded, but the video left as is (just like when playing directly via the app)… and yet. Any clue?
Logs
Jul 26, 2021 14:25:07.779 [0x7f0156d3eb38] DEBUG - Unable to obtain value for audio.profile
Jul 26, 2021 14:25:07.779 [0x7f0156d3eb38] DEBUG - MDE: no remuxable profile found, so video stream will be transcoded
Jul 26, 2021 14:25:07.780 [0x7f0156d3eb38] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Jul 26, 2021 14:25:07.780 [0x7f0156d3eb38] DEBUG - Scaled up video bitrate to 69871Kbps based on 4.500000x fudge factor.
Jul 26, 2021 14:25:07.780 [0x7f0156d3eb38] DEBUG - All to Play For: unable to obtain value for audio.profile
Jul 26, 2021 14:25:07.780 [0x7f0156d3eb38] DEBUG - MDE: Cannot direct stream audio stream due to profile or setting limitations
Jul 26, 2021 14:25:07.780 [0x7f0156d3eb38] DEBUG - MDE: selected media 0 / 4841
Jul 26, 2021 14:25:07.783 [0x7f0156d3eb38] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jul 26, 2021 14:25:07.783 [0x7f0156d3eb38] DEBUG - Selecting best audio stream for part ID 4842 (autoselect: 1 language: en)
Jul 26, 2021 14:25:07.783 [0x7f0156d3eb38] DEBUG - We're going to try to auto-select a subtitle.
Jul 26, 2021 14:25:07.783 [0x7f0156d3eb38] DEBUG - Subtitles: Found a candidate subtitle language [eng] for a foreign film
Jul 26, 2021 14:25:07.783 [0x7f0156d3eb38] DEBUG - Audio Stream: 13118, Subtitle Stream: 13119
Jul 26, 2021 14:25:07.784 [0x7f0156d3eb38] DEBUG - Scaled up video bitrate to 70317Kbps based on 4.500000x fudge factor.
Jul 26, 2021 14:25:07.785 [0x7f0156d3eb38] DEBUG - MDE: Selected protocol http; container: mkv
Jul 26, 2021 14:25:07.785 [0x7f0156d3eb38] DEBUG - MDE: analyzing media item 4842
Profile
<?xml version="1.0" encoding="utf-8"?>
<Client name="iOS">
  <!-- Author: Plex Inc. -->
  <!-- This profile is used by A10X (and later) iOS (2017+) devices using the MPV ("experimental") video player. Currently, this requires a Plex Pass subscription. -->
  <!-- Because Plex does not currently support TrueHD or DTS-MA playback in the client, this audio is transcoded to FLAC. -->
  <Settings>
    <Setting name="DirectPlayStreamSelection" value="true" />
    <Setting name="StreamUnselectedIncompatibleAudioStreams" value="true" />
  </Settings>
  <TranscodeTargets>
    <VideoProfile container="mkv" codec="h264,h265" audioCodec="flac" />
    <MusicProfile container="alac" codec="alac" />
    <PhotoProfile container="jpeg" />
    <SubtitleProfile container="webvtt" subtitleCodec="webvtt"/>
  </TranscodeTargets>
  <DirectPlayProfiles>
    <VideoProfile container="mkv,mov,mp4,mpegts,mpeg,mpegvideo,avi,flv,ogg" codec="h265,h264,hevc,vp8,vp9,h263,mpeg1video,mpeg2video,mpeg4,vc1" audioCodec="aac,aac_latm,ac3,alac,flac,dca,vorbis,opus,eac3,mp1,mp2,mp3" subtitleCodec="ass,dvb_subtitle,vobsub,eia_608,pgs,microdvd,movtext,ssa,srt" />
    <VideoProfile protocol="hls" container="mkv,mov,mp4,mpegts,mpeg,mpegvideo,avi,flv,ogg" codec="h265,h264,hevc,vp8,vp9,h263,mpeg1video,mpeg2video,mpeg4,vc1" audioCodec="aac,aac_latm,ac3,alac,flac,dca,vorbis,opus,eac3,mp1,mp2,mp3" subtitleCodec="ass,dvb_subtitle,vobsub,eia_608,pgs,microdvd,movtext,ssa,srt" />
    <MusicProfile container="mp3" codec="mp3" />
    <MusicProfile container="m4a" codec="aac,alac" />
    <MusicProfile container="mp4" codec="aac,he-aac,ac3,eac3,alac" />
    <MusicProfile container="flac,mkv" codec="flac" />
  </DirectPlayProfiles>
  <CodecProfiles>
  <VideoCodec name="*">
     <Limitations>
       <UpperBound name="video.width" value="3840" isRequired="true"/>
       <UpperBound name="video.height" value="2160" isRequired="true"/>
       <UpperBound name="video.bitDepth" value="10" />
     </Limitations>
    </VideoCodec>
    <VideoAudioCodec name="*">
      <Limitations>
        <UpperBound name="audio.channels" value="2" onlyTranscodes="true" />
      </Limitations>
    </VideoAudioCodec>
  </CodecProfiles>
</Client>
Media Info
Video
Count                                    : 377
Count of stream of this kind             : 1
Kind of stream                           : Video
Stream identifier                        : 0
StreamOrder                              : 0
Unique ID                                : 2716201297508956081
Format                                   : HEVC
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format/Url                               : http://www.itu.int
Commercial name                          : HEVC
Format profile                           : Main 10@L5.1@Main
Internet media type                      : video/H265
Codec ID                                 : V_MPEGH/ISO/HEVC
Duration                                 : 1958180.000000
Duration                                 : 32 min 38 s
Duration                                 : 32 min 38 s 180 ms
Duration                                 : 00:32:38.180
Duration                                 : 00:32:38:09
Duration                                 : 00:32:38.180 (00:32:38:09)
Bit rate                                 : 15453280
Bit rate                                 : 15.5 Mb/s
Width                                    : 3840
Width                                    : 3 840 pixels
Height                                   : 2160
Height                                   : 2 160 pixels
Sampled_Width                            : 3840
Sampled_Height                           : 2160
Pixel aspect ratio                       : 1.000
Display aspect ratio                     : 1.778
Display aspect ratio                     : 16:9
Frame rate mode                          : CFR
Frame rate mode                          : Constant
Frame rate                               : 50.000
Frame rate                               : 50.000 FPS
Frame count                              : 97909
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 10
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.037
Delay                                    : 0
Delay                                    : 00:00:00.000
Delay, origin                            : Container
Stream size                              : 3782538124
Stream size                              : 3.52 GiB (95%)
Stream size                              : 4 GiB
Stream size                              : 3.5 GiB
Stream size                              : 3.523 GiB
Proportion of this stream                : 0.95210
Default                                  : Yes
Default                                  : Yes
Forced                                   : No
Forced                                   : No
colour_description_present               : Yes
colour_description_present_Source        : Stream
Color range                              : Limited
colour_range_Source                      : Stream
Color primaries                          : BT.709
colour_primaries_Source                  : Stream
Transfer characteristics                 : BT.709
transfer_characteristics_Source          : Stream
Matrix coefficients                      : BT.709
matrix_coefficients_Source               : Stream
Audio
Count                                    : 306
Kind of stream                           : Audio
StreamOrder                              : 1
Unique ID                                : 1
Format                                   : E-AC-3
Format                                   : E-AC-3 JOC
Format/Info                              : Enhanced AC-3 with Joint Object Coding
Format/Url                               : https://en.wikipedia.org/wiki/Dolby_Digital_Plus
Commercial name                          : Dolby Digital Plus with Dolby Atmos
Format settings, Endianness              : Big
Format_AdditionalFeatures                : JOC
Internet media type                      : audio/eac3
Codec ID                                 : A_EAC3
Duration                                 : 1958176.000000
Duration                                 : 32 min 38 s 176 ms
Duration                                 : 00:32:38.176
Duration                                 : 00:32:53:30
Duration                                 : 00:32:38.176 (00:32:53:30)
Bit rate mode                            : CBR
Bit rate mode                            : Constant
Bit rate                                 : 768000
Bit rate                                 : 768 kb/s
Channel(s)                               : 6
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Channel positions                        : 3/2/0.1
Channel layout                           : L R C LFE Ls Rs
Samples per frame                        : 1536
Sampling rate                            : 48000
Sampling rate                            : 48.0 kHz
Samples count                            : 93992448
Frame rate                               : 31.250
Frame rate                               : 31.250 FPS (1536 SPF)
Frame count                              : 61193
Compression mode                         : Lossy
Delay                                    : 0
Delay relative to video                  : 0
Delay relative to video                  : 00:00:00.000
Stream size                              : 187984896
Stream size                              : 179 MiB (5%)
Stream size                              : 179.3 MiB
Proportion of this stream                : 0.04732
Title                                    : English [Original]
Language                                 : en
Language                                 : English
Language                                 : English
Language                                 : en
Language                                 : eng
Language                                 : en
Service kind                             : CM
Service kind                             : Complete Main
Default                                  : Yes
Default                                  : Yes
Forced                                   : No
Forced                                   : No
Complexity index                         : 16
Number of dynamic objects                : 15
Bed channel count                        : 1
Bed channel count                        : 1 channel
Bed channel configuration                : LFE
bsid                                     : 16
dialnorm                                 : -25
dialnorm                                 : -25 dB
compr                                    : -0.28
compr                                    : -0.28 dB
acmod                                    : 7
lfeon                                    : 1
dialnorm_Average                         : -25
dialnorm_Average                         : -25 dB
dialnorm_Minimum                         : -25
dialnorm_Minimum                         : -25 dB
dialnorm_Maximum                         : -25
dialnorm_Maximum                         : -25 dB
dialnorm_Count                           : 2072
compr_Average                            : -1.57
compr_Average                            : -1.57 dB
compr_Minimum                            : -8.52
compr_Minimum                            : -8.52 dB
compr_Maximum                            : 4.86
compr_Maximum                            : 4.86 dB
compr_Count                              : 1364
I was actually really, really close. Here is the profile that allows me to download pretty much anything and everything to my iPad: iPad Pro 12.9 (2021 / M1) + PleX - Sync'ing 4K HVEC / H.265 content without transcoding · GitHub
