Server Version: 1.32.5.7349 (Docker image lscr.io/linuxserver/plex:latest running on a x86_64 Ubuntu 23.04 server)
Player Version: 4.108.0 (?), Google Chrome Version 116.0.5845.111 (Official Build) (64-bit)
I noticed the server was transcoding audio only for eac3 codec on my Samsung TV and Chrome. Video was direct stream or direct play:
Probing the video file you can see there is nothing extraordinary in it.. but it seems Samsung and Chrome didn’t like the audio codec..
Input #0, matroska,webm, from 'video.mkv':
Metadata:
encoder : libebml v1.4.0 + libmatroska v1.6.1
Duration: 00:55:32.13, start: 0.000000, bitrate: 3618 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p(tv, bt709, progressive), 1356x678 [SAR 1:1 DAR 2:1], 23.98 fps, 23.98 tbr, 1k tbn (default)
Stream #0:1(eng): Audio: eac3, 48000 Hz, 5.1(side), fltp, 768 kb/s (default)
Stream #0:2(eng): Subtitle: subrip (default)
Metadata:
title : English
DURATION : 00:47:44.260000000
Stream #0:3(por): Subtitle: subrip
Metadata:
title : Portuguese
Stream #0:4(por): Subtitle: subrip
Metadata:
title : Portuguese Brazilian
DURATION : 00:46:00.323000000
Even though audio transcoding is not CPU heavy, I decided to use FFMpeg to convert the audio to AAC to make the files more player compatible…
$ ffmpeg -hwaccel auto -hide_banner -i video.mkv -map 0 -c:v copy -c:a aac -c:s copy 'othervideo.mkv'
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Stream #0:1 -> #0:1 (eac3 (native) -> aac (native))
Stream #0:2 -> #0:2 (copy)
Stream #0:3 -> #0:3 (copy)
Stream #0:4 -> #0:4 (copy)
Press [q] to stop, [?] for help
[aac @ 0x5582685740c0] Using a PCE to encode channel layout "5.1(side)"
That gives me an almost identical file.. except the encoder version, the video bitrate (?) and the audio codec:
Input #0, matroska,webm, from 'othervideo.mkv':
Metadata:
ENCODER : Lavf59.27.100
Duration: 00:55:32.15, start: 0.000000, bitrate: 3242 kb/s
Metadata:
DURATION : 00:55:32.141000000
Stream #0:1(eng): Audio: aac (LC), 48000 Hz, 6 channels, fltp (default)
Metadata:
ENCODER : Lavc59.37.100 aac
DURATION : 00:55:32.149000000
Metadata:
title : English
Metadata:
title : Portuguese
Metadata:
So the expectation was that players would have direct play / stream all the way. However, Plex Web in Chrome gives me now an error “Error code: s3014 (Media)” and does not play.
Android does play but video AND audio are being transcoded… which is worse than I had before:
I have no idea what is happening here… any ideas?
