Plex VR
Initial release of Plex VR supports Google Daydream. 1.0
User feedback forum section https://forums.plex.tv/categories/plex-vr
Support doc https://support.plex.tv/articles/plex-vr-for-daydream/
Current release 1.1.2.111
NEW:
  • ‘Watch Together’ now supported in Android Oreo.
    FIXES:
  • Display ‘Plex VR’ instead of ‘Plex’ inside device settings
Plex VR 1.1.3
Available on Google Play.
FIXES:
  • Make sure app works when device is offline.
Plex VR 1.2.0
NEW:
  • Redesigned launcher icons.
  • Application logs can now be shared using ‘Support’ action in settings.
FIXES:
  • Playback controls were too low for 180 and 360 content.
  • Skipping ahead during playback would reset the stereo and projection modes.
  • Headphones being plugged in or out were not detected during a Watch Together session.
  • Don’t show ‘share with friends?’ dialog before playback if playing local content.
  • Hide ‘This Device’ server during a Watch Together session.
Plex VR 1.2.1
Available on the Gear VR store.
NEW:
FIXES:
  • Play 3D version if multiple versions available for selected item.
An update of Plex VR for Daydream will be submitted to Google Play soon.
Plex VR 1.3.0
Available on the Gear VR/Oculus store.
NEW:
  • Darker evening lighting in Luxury Apartment scene.
  • Support for Daydream standalone VR headsets.
  • First run tutorial explaining how to install Plex Media Server.
  • Helpful message if no local videos are available.
FIXES:
  • Aliasing in Luxury Apartment scene.
  • Screen vertical position in Void scene.
  • Remember previously selected scene when app is restarted.
  • Don’t stop video playback when switching to a different scene
  • Move settings a bit higher in drive-in scene so that no buttons are hidden.
  • Reduce interactable area around horn in drive-in cars, makes it easier to select menu items.
  • Start with screen in a lower position in the Void scene.
  • [Oculus Only] Lights now dim when shades come down.
  • [Oculus Only] Make sure coffee table doesn’t block laser pointer during login.
  • [Oculus Only] Fix laser pointer selection of buttons in ‘Search’ dialog.
Plex VR 1.4.0
NEW:
  • [Gear VR / Go] Add support for the Watch Together feature.
  • Virtual surround sound (simulated 5.1) now available for Plex Pass users.
  • Allow selection of the right version before playback.
FIXES:
  • [Gear VR / Go] The keyboard is now positioned correctly in the Drive In scene.
  • Fixed video thumbnail aspect ratios.
Plex VR 1.4.0
FIXES:
  • Fixed playback artifacts playing some 3D videos.
NEW:
  • [Daydream] Bump minimum required version of Android to 8 (Oreo).
Plex VR 1.4.1
FIXES:
NEW:
Plex VR 1.4.2
FIXES:
  • [Gear VR] Fixed gaze icon visibility.
Plex VR 1.5.0
Will be available soon on the Gear VR/Oculus store.
NEW:
  • Add support for audio and subtitle stream selection.
FIXES:
  • [Daydream] Fix on-screen keyboard.
  • [Daydream] Close settings screen with ‘menu’ button.
  • [Gear VR / Go] Don’t use trigger to select things.
  • [Lenovo Standalone] Increased couch colliders to hide them if you’re behind them.
  • Loft: don’t move blinds up and down too often.
