Plex web slow item loading
@carrousel5301
Thank you for the logs.
They are clean.
May I ask how many items are loading in Plex web ?
Also which player device (PC? phone? tablet?)
There are about 9,000 movies in this library.
I’m testing in the browser currently as I can easily use devtools to check the network calls. But this affects all clients (Shield, Apple TV, PMP).
When I check recently added items they don’t contain the extra information in the taggings table. They seem to get added a few days > week later.
FWIW I’ve also tried enabling/disabling the Scheduled Tasks that refresh metadata. It doesn’t seem to make a difference. Refreshing an item manually also doesn’t seem to add the extra rows
Just as another example, the movie “Unthinkable”
Here is the XML from “View XML”, this took 17 seconds to load with the URL. Playback takes the same amount of time.
https://plex_direct_url:32400/library/metadata/714097?checkFiles=1&includeAllConcerts=1&includeBandwidths=1&includeChapters=1&includeChildren=1&includeConcerts=1&includeExtras=1&includeFields=1&includeGeolocation=1&includeLoudnessRamps=1&includeMarkers=1&includeOnDeck=1&includePopularLeaves=1&includePreferences=1&includeRelated=1&includeRelatedCount=1&includeReviews=1&includeStations=1&X-Plex-Token=plex_token
unthinkables.txt (35.6 KB)
And has the following entries in the taggings table.
taggings.txt (11.3 KB)
Deleting all of the tag_id 100 and 101 entries with the extra image urls makes the XML and playback load nearly instantly.
9000 movies?
:scream:
WTH?
How big is your DB? it must be huge!
I know you have an i9, which is more than enough ‘crunch’ power but is the rest of the machine able to keep up?
– PMS APP_SUPP_DIR on SSD?
– How much RAM in the server machine ?
STUPID question time:
  1. How much memory in the Plex/web machine being used?
  2. How’s it connected to the server ? (WiFi involved?)
I’m about to go into a server team meeting.
If I need to, might it be possible to arrange obtaining a copy of your database so I can construct a ‘dummy test’ library (fake files instead of real ones)?
Sure, I’d be happy to provide a copy of the database. It’s about 3GB currently, but I’ll trim it down a bit by removing some of the excess libraries. (I’ll double check the issue persists afterwards)
64GB ram, only 6GB is used currently. The entire PMS install directory is on an Intel 900P Optane drive (They were on sale :upside_down_face: )
FWIW I don’t think this is an IO issue. I’ve ran the DB on a ram-disk previously and it also did not help. I’d be surprised if pulling 10-20 extra rows from the table is actually causing the issue.
Is it possible PMS is unintentionally doing something with those poster URLs that would cause a playback delay?
Please don’t trim down the DB.
I am writing here while in my meeting.
Engineering would like a copy of your DB – AS IS
and then basic “How to Repro” steps.
What I’ll do is create the dummy test files to support the scanner requirement.
What I’ll do is build up a contained replica of your server on my test machine then give the entire environment to Engineering to do their magic.
Sent!
As far as reproducing the issue, it can be found with nearly every item in this library.
View XML of an item, most times it’ll take 15~ seconds or longer. Those are the items that typically take a similarly long time to start or faily alltogether.
The Burbs
2 Guns
3 From Hell
Back to the Future
The Batman
etc…
Very interesting. I only have 250 4K movies and almost 1000 1080p movies in a different library and the db size is around 55 MB (on a nvme ssd)… How did you check the tagging tables?
@ChuckPa May I ask if you found something in my logs or in the io results I posted?
I used this to open the DB https://sqlitebrowser.org/
Make sure Plex is stopped. Maybe make a backup just in case you accidentally make a change you weren’t planning on.
I used the item id(ratingkey) and filtered the metadata id by that number. This shows all of the different info for that item and a ton of extra fields that don’t seem necessary in my instance.
@Mitzsch
I’ve not found anything specific. I’m now looking at @carrousel5301 and seeing the same “Lack of errors”.
Something is very fishy.
Given I have his DB, I’m reconstructing a “dummy media” environment :roll_eyes: LOL
When that’s done, I will spin up a LXC of my own with that media and see what happens.
From there, I will have a self-contained dataset to give to Engineering.
oke, thanks!
Very curious about what is going on, with the database…
I will probably have a look at mine via sqlitebrowser. (thx @carrousel5301) Maybe there are also those extra fields…
@ChuckPa
If you also need my db - I can also send it! :slight_smile:
Folks:
Engineering would like to know more about the ‘tags’ being used.
“100” and “101” don’t provide enough context.
May we have more details please?
PMS is adding those, they’re just in the taggings table.
7525935	714097	100	1	https://image.tmdb.org/t/p/original/6yQqguytl10FhImngDHV90Aqewa.jpg			metadata://posters/tv.plex.agents.movie_2c1ac200b6e37275c3448695df42902aac624520	1697657203	at%3Asource=tmdb
7525936	714097	100	2	https://image.tmdb.org/t/p/original/cdflfHuWlByLHRa36FvRQCilufR.jpg			metadata://posters/tv.plex.agents.movie_02f3518fecac86fc9e88241285aac3ce96b890ee	1697657203	at%3Asource=tmdb
7525937	714097	100	3	https://image.tmdb.org/t/p/original/kkkY8jyz4pj5NSnoV1dBl4HrKq4.jpg			metadata://posters/tv.plex.agents.movie_4a3ece2ebbb37401b199cf07c43acd0c16d3311f	1697657203	at%3Asource=tmdb
7525925	714097	101	1	https://image.tmdb.org/t/p/original/49jYVh3QB35kw8HNYj81Z4LI5QL.jpg			metadata://art/tv.plex.agents.movie_d66c5c2175c1e2207e932d296a5186c829cf84cb	1697657203	at%3Asource=tmdb
7525926	714097	101	2	https://image.tmdb.org/t/p/original/p80dRTtTQE5U7FeDoJXanxFX2xO.jpg			metadata://art/tv.plex.agents.movie_7fd30fcff8691bb18b99f9afb6e32d9df1ccea49	1697657203	at%3Asource=tmdb
7525927	714097	101	3	https://image.tmdb.org/t/p/original/zO9aQ0zh3FGqPzrvNpTjd2kHMEZ.jpg			metadata://art/tv.plex.agents.movie_1d50049bf007373ac9fa2130dad194ff35feadc8	1697657203	at%3Asource=tmdb
I don’t think they correlate with the “tags” for each item, or they don’t seem to. This item is not in a collection either.
Thanks… Relaying
And just to reiterate, a simple poster change on items makes the item unplayable. Only way to get it to play again is to unmatch it and then rematch it. Using the legacy agent, no problem at all changing posters and playing the file. I am assuming all of this is related.
Thanks for bringing that up!
@ChuckPa To reproduce this, on the database I sent you I changed the poster for Halloween 2. This was added recently.
Here is the before and after of the taggings table
I used the built-in poster edit tool. Edit > Posters and choose one at random.
Before changing poster
8079705	875579	100	0	https://image.tmdb.org/t/p/original/vSHPM4LQDpWdQrD5KZWK6wNqSOD.jpg			metadata://posters/tv.plex.agents.movie_a35708dd6033335bc5883e3e60b4329fd05d4759	1698070346
8079706	875579	100	1	eb371b29c290bdec3448814296a6bfd7			metadata://posters/c8d94005ca817d5dd0045ecd36221a9b0ef520e7	1698070346	at%3Asource=local
8079707	875579	101	0	https://image.tmdb.org/t/p/original/4HqACXxiislm5ye685mOUNwfatb.jpg			metadata://art/tv.plex.agents.movie_4ebad33d1311239ae5680acaa5a351dd035bc754	1698070346
8079708	875579	101	1	7a85e9167df2c85a1f4715d9cb2fa997			metadata://art/0b255b2155b03e1f696e380f08ba1ce36c80ca45	1698070346	at%3Asource=local
After Changing poster
8079848	875579	101	0	7a85e9167df2c85a1f4715d9cb2fa997			metadata://art/0b255b2155b03e1f696e380f08ba1ce36c80ca45	1698070346	at%3Asource=local
8079849	875579	101	1	https://image.tmdb.org/t/p/original/4HqACXxiislm5ye685mOUNwfatb.jpg			metadata://art/tv.plex.agents.movie_4ebad33d1311239ae5680acaa5a351dd035bc754	1698083811	at%3Asource=tmdb
8079850	875579	101	2	https://image.tmdb.org/t/p/original/4UiNo0vUAKLgO9xq1JKYsGQ9avo.jpg			metadata://art/tv.plex.agents.movie_576fb94c01c82eb0206558d8effc3bfd796f2676	1698083811	at%3Asource=tmdb
8079851	875579	101	3	https://image.tmdb.org/t/p/original/qpN34S9p9aUCspJIleV3inARv1t.jpg			metadata://art/tv.plex.agents.movie_9730974338a41aadce23682debb53b3381a47f06	1698083811	at%3Asource=tmdb
8079852	875579	101	4	https://image.tmdb.org/t/p/original/4zHTwd5k5UDJCrYObTUr927qEUW.jpg			metadata://art/tv.plex.agents.movie_6b0bf8fcb8c0b91a326e27e23780347c482af6ad	1698083811	at%3Asource=tmdb
8079853	875579	101	5	https://image.tmdb.org/t/p/original/sn6x8yiTShjJlPJw1fOXF44oK1n.jpg			metadata://art/tv.plex.agents.movie_fb260b3edfb3b7b95d9ab3f1dd7e97975994e0dd	1698083811	at%3Asource=tmdb
8079854	875579	101	6	https://image.tmdb.org/t/p/original/378twvs9moAbJ79uqZlNaZgxCwd.jpg			metadata://art/tv.plex.agents.movie_48de575f950ca5a951d1e20947d27d36b64398d2	1698083811	at%3Asource=tmdb
8079855	875579	101	7	https://image.tmdb.org/t/p/original/nQ1U3KmVxsA5mXwlxnT0EmthSB0.jpg			metadata://art/tv.plex.agents.movie_9a8c31b24a58a1df3937ad0e201298b322315316	1698083811	at%3Asource=tmdb
8079856	875579	101	8	https://image.tmdb.org/t/p/original/5zIQV1MczzyXuaTc0XOgtP3CWE7.jpg			metadata://art/tv.plex.agents.movie_ce80db4728b510403cc993b7955d27639ebc2fcf	1698083811	at%3Asource=tmdb
8079857	875579	101	9	https://image.tmdb.org/t/p/original/2DzAr4ACFZY1ijSNOxVSQz6ppz4.jpg			metadata://art/tv.plex.agents.movie_e95a0606d854482c24cd0316a003215da24fe00b	1698083811	at%3Asource=tmdb
8079858	875579	101	10	https://image.tmdb.org/t/p/original/jwCYHCvn421Fy7MA0abvOhc7woo.jpg			metadata://art/tv.plex.agents.movie_b9d8407e0d4798f503060b01855e455f7b13197e	1698083811	at%3Asource=tmdb
8079859	875579	101	11	https://artworks.thetvdb.com/banners/movies/2802/backgrounds/2802.jpg			metadata://art/tv.plex.agents.movie_5795f623f9f1637b377f94eef775a574f2e06db2	1698083811	at%3ApreviewKey=https%3A%2F%2Fartworks%2Ethetvdb%2Ecom%2Fbanners%2Fmovies%2F2802%2Fbackgrounds%2F2802_t%2Ejpg&at%3Asource=tvdb
8079860	875579	101	12	http://assets.fanart.tv/fanart/movies/24150/moviebackground/halloween-ii-57fe363705e3e.jpg			metadata://art/tv.plex.agents.movie_21d147546f9bb12f13ed0f6237020f1e9ffcd0f0	1698083811	at%3ApreviewKey=http%3A%2F%2Fassets%2Efanart%2Etv%2Fpreview%2Fmovies%2F24150%2Fmoviebackground%2Fhalloween-ii-57fe363705e3e%2Ejpg&at%3Asource=fanarttv
8079861	875579	101	13	http://assets.fanart.tv/fanart/movies/24150/moviethumb/halloween-ii-5740278390315.jpg			metadata://art/tv.plex.agents.movie_d5ecedb335abf42632a32726b5dce48ddbda29b8	1698083811	at%3ApreviewKey=http%3A%2F%2Fassets%2Efanart%2Etv%2Fpreview%2Fmovies%2F24150%2Fmoviethumb%2Fhalloween-ii-5740278390315%2Ejpg&at%3Asource=fanarttv
8079862	875579	101	14	http://assets.fanart.tv/fanart/movies/24150/moviebackground/halloween-ii-51f27246d5478.jpg			metadata://art/tv.plex.agents.movie_f3a640848b5eb946ee3a2950562c7b620c6f7b0a	1698083811	at%3ApreviewKey=http%3A%2F%2Fassets%2Efanart%2Etv%2Fpreview%2Fmovies%2F24150%2Fmoviebackground%2Fhalloween-ii-51f27246d5478%2Ejpg&at%3Asource=fanarttv
8079863	875579	101	15	https://metadata-static.plex.tv/a/gracenote/a98dfdb73246e669c4683e14ee29f65e.jpg			metadata://art/tv.plex.agents.movie_5a436837d02bd594582aa0ec8dff3a7aa6142717	1698083811	at%3Asource=gracenote
8079864	875579	101	16	https://metadata-static.plex.tv/4/gracenote/4811b64da95636eb088760cb0d2e901b.jpg			metadata://art/tv.plex.agents.movie_7c91fc4f8b81b4a82b01355bf4f398761b529fbb	1698083811	at%3Asource=gracenote
8079865	875579	101	17	https://metadata-static.plex.tv/3/gracenote/34439e79818540ef062da3e0cb443b0f.jpg			metadata://art/tv.plex.agents.movie_b0c91131cc15c097e88d7ead93abdd793ea65208	1698083811	at%3Asource=gracenote
8079866	875579	101	18	https://metadata-static.plex.tv/5/gracenote/500e8a1585296e88808bbc3e441d34dd.jpg			metadata://art/tv.plex.agents.movie_da68a2a4de5ddac89ee84d708795914a6f819731	1698083811	at%3Asource=gracenote
8079867	875579	101	19	https://metadata-static.plex.tv/e/gracenote/ee6904e394fad92c753e465525c51ebc.jpg			metadata://art/tv.plex.agents.movie_4f71751c7ed1b7f3e71c708b602db90b28a5c07f	1698083811	at%3Asource=gracenote
8079868	875579	101	20	https://metadata-static.plex.tv/2/gracenote/28f9902f87b2b0fa26f464b72a53fcfa.jpg			metadata://art/tv.plex.agents.movie_147ec1d08c1243f34c0350d14029cc1376a8f966	1698083811	at%3Asource=gracenote
8079869	875579	101	21	https://metadata-static.plex.tv/a/gracenote/a1cc823f868a286151c1061a0ffba353.jpg			metadata://art/tv.plex.agents.movie_094b10c1d0fdf34b8a722ceeb0b1897771cad49d	1698083811	at%3Asource=gracenote
8079870	875579	101	22	https://metadata-static.plex.tv/1/gracenote/1467288068fb8b33d477c3416b1ccc10.jpg			metadata://art/tv.plex.agents.movie_4e903c17dbcd622e9b937a1a4c34d02b8f982837	1698083811	at%3Asource=gracenote
8079871	875579	101	23	https://metadata-static.plex.tv/1/gracenote/1e3ec4ea2ec7bd775ee09df4a1f5ec30.jpg			metadata://art/tv.plex.agents.movie_c1f8a9d475022cb2b78a42a10bc7ad6ed7932319	1698083811	at%3Asource=gracenote
8079872	875579	100	0	eb371b29c290bdec3448814296a6bfd7			metadata://posters/c8d94005ca817d5dd0045ecd36221a9b0ef520e7	1698070346	at%3Asource=local
8079873	875579	100	1	https://image.tmdb.org/t/p/original/vSHPM4LQDpWdQrD5KZWK6wNqSOD.jpg			metadata://posters/tv.plex.agents.movie_a35708dd6033335bc5883e3e60b4329fd05d4759	1698083811	at%3Asource=tmdb
8079874	875579	100	2	https://image.tmdb.org/t/p/original/ojXae8lLAdMDXvf6nD9mFqGufPE.jpg			metadata://posters/tv.plex.agents.movie_22c0da583df6449a35f9b46d99a96b02ae149d85	1698083811	at%3Asource=tmdb
8079875	875579	100	3	https://image.tmdb.org/t/p/original/2M2sW62SiKjYNWlWw9Z0crNrbUl.jpg			metadata://posters/tv.plex.agents.movie_accd9a4b4f797006504b9ba9d689393e9527fd0e	1698083811	at%3Asource=tmdb
8079876	875579	100	4	https://image.tmdb.org/t/p/original/9pQpQz9sgH5ViBnfp8hcwR3W9LF.jpg			metadata://posters/tv.plex.agents.movie_d326dd1ab7c91f7517e2000b5bb8ea6b1e16f9ff	1698083811	at%3Asource=tmdb
8079877	875579	100	5	https://image.tmdb.org/t/p/original/1nxRKN5L95B8LDfm2ypnpSSRfh2.jpg			metadata://posters/tv.plex.agents.movie_066aa798d07cfc02a7739ae94c6d2c31c068e91b	1698083811	at%3Asource=tmdb
8079878	875579	100	6	https://image.tmdb.org/t/p/original/2kSPc36MzB4uQfPPmM0lG646Vho.jpg			metadata://posters/tv.plex.agents.movie_86a9aca45e00c1a11e3a30ea688d53910c4b9c92	1698083811	at%3Asource=tmdb
8079879	875579	100	7	https://image.tmdb.org/t/p/original/da235Qc6CtbyxKEJ4Hz6BY9Y20D.jpg			metadata://posters/tv.plex.agents.movie_af76aa1e6df0469be361cfa23f575db938510077	1698083811	at%3Asource=tmdb
8079880	875579	100	8	https://image.tmdb.org/t/p/original/ab25c3whEnGwkpwBwm73MSgQj8h.jpg			metadata://posters/tv.plex.agents.movie_cc4c61fa8e6c261a3bdb740f0c715e69a602ad1e	1698083811	at%3Asource=tmdb
8079881	875579	100	9	https://image.tmdb.org/t/p/original/f5Q2m14bmx2aN0uQJj2WbGTuXo6.jpg			metadata://posters/tv.plex.agents.movie_fed0ed1991c416d6cd2f1583c7f7ba535aa2c7a4	1698083811	at%3Asource=tmdb
8079882	875579	100	10	https://image.tmdb.org/t/p/original/1nB07kREA4Pdrhv8gQJswrKingN.jpg			metadata://posters/tv.plex.agents.movie_414d827f4c8d88893b57ccbd2df114ae349e7006	1698083811	at%3Asource=tmdb
8079883	875579	100	11	https://image.tmdb.org/t/p/original/i2AElOIgwDjORIa4jpHFsUXOltY.jpg			metadata://posters/tv.plex.agents.movie_ab2fa70e22177f467b6f715cdc7d3a27fc7848b0	1698083811	at%3Asource=tmdb
8079884	875579	100	12	https://image.tmdb.org/t/p/original/5F5KyvPV1BESAvp9Hjr9GMTm2pB.jpg			metadata://posters/tv.plex.agents.movie_256f083f09b747b84947a3f5cf54ff40c189cd6d	1698083811	at%3Asource=tmdb
8079885	875579	100	13	https://image.tmdb.org/t/p/original/iZlV8xVuWZugsgc3yri1lJoOpue.jpg			metadata://posters/tv.plex.agents.movie_dd5c6960869fd6d885ad5531ab0ca0a2dfe6d050	1698083811	at%3Asource=tmdb
8079886	875579	100	14	https://image.tmdb.org/t/p/original/amcJB7hm0QTxzA2RuLHwo6gFmhp.jpg			metadata://posters/tv.plex.agents.movie_8c9d22f16cc2627900c68a337d0993b6e5cea32a	1698083811	at%3Asource=tmdb
8079887	875579	100	15	https://image.tmdb.org/t/p/original/eahmuQtIWKfp9Atg3pOHpV95w4m.jpg			metadata://posters/tv.plex.agents.movie_fe398605682fdc92b31bffa27f74c848d44f9619	1698083811	at%3Asource=tmdb
8079888	875579	100	16	https://image.tmdb.org/t/p/original/eUERhu9cTg63MrjOolUTWwi0FNG.jpg			metadata://posters/tv.plex.agents.movie_590d01369e848c0eedd4defd13ace7aa19dd0f1e	1698083811	at%3Asource=tmdb
8079889	875579	100	17	https://image.tmdb.org/t/p/original/HbOcIVtfWGICWeY43oUm1UxSm7.jpg			metadata://posters/tv.plex.agents.movie_b9f4ae5fa8dd5c399df9453532b927df70e1070a	1698083811	at%3Asource=tmdb
8079890	875579	100	18	https://image.tmdb.org/t/p/original/nYLro5447nXPB5TFNMKuMHq3Ri3.jpg			metadata://posters/tv.plex.agents.movie_ae7b85e647efd3ad75ed2cd15782548a6a3dbfa7	1698083811	at%3Asource=tmdb
8079891	875579	100	19	https://image.tmdb.org/t/p/original/fwQJmzcLNxiCIcOisGSQGzQxLCH.jpg			metadata://posters/tv.plex.agents.movie_f56a371689ddbcb084f5faa0088d648e3ddcfbc4	1698083811	at%3Asource=tmdb
8079892	875579	100	20	https://image.tmdb.org/t/p/original/4EchuaRaR2CkCj2ZIA7RtSghc7s.jpg			metadata://posters/tv.plex.agents.movie_a46d5968cefa7ec93420c6a5aad9ea7ff19346d8	1698083811	at%3Asource=tmdb
8079893	875579	100	21	https://image.tmdb.org/t/p/original/bv1rgnvNAgwmBdHxeqkL77SejpJ.jpg			metadata://posters/tv.plex.agents.movie_da9428f84bf6e14a7214fb48d2317bdae19adf91	1698083811	at%3Asource=tmdb
8079894	875579	100	22	https://image.tmdb.org/t/p/original/sYqQ1kOiDLmyEvp2FXiFyMc94rs.jpg			metadata://posters/tv.plex.agents.movie_b2e7ea5df2965a9562d7b3950fe9df15c11c8d13	1698083811	at%3Asource=tmdb
8079895	875579	100	23	https://image.tmdb.org/t/p/original/9EQZAGpFU7jYAAyWaWBWpobq5wT.jpg			metadata://posters/tv.plex.agents.movie_e828f6287b6a59bff07cd4106511209a0907b800	1698083811	at%3Asource=tmdb
8079896	875579	100	24	https://image.tmdb.org/t/p/original/w84sVyqktspi7zeu7UOMTAxhAcY.jpg			metadata://posters/tv.plex.agents.movie_644b54381dd227df5ff853dad88adf853918536a	1698083811	at%3Asource=tmdb
8079897	875579	100	25	https://image.tmdb.org/t/p/original/9rT181f5dScYlpELtKJggDqyrcb.jpg			metadata://posters/tv.plex.agents.movie_0b4b8653d0c9de272a100d9fd0cd59fb32a25b8f	1698083811	at%3Asource=tmdb
8079898	875579	100	26	https://image.tmdb.org/t/p/original/ePufCqWgI97w0LAmfGOUhmSCLmm.jpg			metadata://posters/tv.plex.agents.movie_dba9e47653d1f8ab668f4277019f6c11b7c99e78	1698083811	at%3Asource=tmdb
8079899	875579	100	27	https://image.tmdb.org/t/p/original/4tJMossUugMElueQ7WleKsKz0s9.jpg			metadata://posters/tv.plex.agents.movie_601bfbe1ee456fe46c6be2d9d2b9360d16d921ec	1698083811	at%3Asource=tmdb
8079900	875579	100	28	https://image.tmdb.org/t/p/original/A2IMhsMBUaHtb1ijSZZVbB2uNJP.jpg			metadata://posters/tv.plex.agents.movie_92ef323166d9b5713f6492f5a92770201b4a6585	1698083811	at%3Asource=tmdb
8079901	875579	100	29	https://m.media-amazon.com/images/M/MV5BMjE2OTEzODI0NF5BMl5BanBnXkFtZTcwMTE4MTY2Mg@@._V1_.jpg			metadata://posters/tv.plex.agents.movie_23dbeeef46ea013e563b56ef06880155c5a0a731	1698083811	at%3Asource=imdb
8079902	875579	100	30	https://artworks.thetvdb.com/banners/v4/movie/2802/posters/6430d9a20e886.jpg			metadata://posters/tv.plex.agents.movie_867abd0b35df429bbef6b872a66202ea2f158284	1698083811	at%3ApreviewKey=https%3A%2F%2Fartworks%2Ethetvdb%2Ecom%2Fbanners%2Fv4%2Fmovie%2F2802%2Fposters%2F6430d9a20e886_t%2Ejpg&at%3Asource=tvdb
8079903	875579	100	31	https://artworks.thetvdb.com/banners/movies/2802/posters/2802.jpg			metadata://posters/tv.plex.agents.movie_bf553446a70f46427b6f2b0aa39253ed1991ea6a	1698083811	at%3ApreviewKey=https%3A%2F%2Fartworks%2Ethetvdb%2Ecom%2Fbanners%2Fmovies%2F2802%2Fposters%2F2802_t%2Ejpg&at%3Asource=tvdb
8079904	875579	100	32	http://assets.fanart.tv/fanart/movies/24150/movieposter/halloween-ii-5861157237235.jpg			metadata://posters/tv.plex.agents.movie_e90d871f59bdc11ab20967dc6f8579f0e5235a41	1698083811	at%3ApreviewKey=http%3A%2F%2Fassets%2Efanart%2Etv%2Fpreview%2Fmovies%2F24150%2Fmovieposter%2Fhalloween-ii-5861157237235%2Ejpg&at%3Asource=fanarttv
8079905	875579	100	33	http://assets.fanart.tv/fanart/movies/24150/movieposter/halloween-ii-5860ef8c9ea60.jpg			metadata://posters/tv.plex.agents.movie_319094c114e9f4b2da2a2b13c381ddb046ef4c47	1698083811	at%3ApreviewKey=http%3A%2F%2Fassets%2Efanart%2Etv%2Fpreview%2Fmovies%2F24150%2Fmovieposter%2Fhalloween-ii-5860ef8c9ea60%2Ejpg&at%3Asource=fanarttv
8079906	875579	100	34	https://metadata-static.plex.tv/f/gracenote/fe04989601d3c82363f4bb5680219272.jpg			metadata://posters/tv.plex.agents.movie_1e8d25db4c32dcefbc2b79776d5a7ca031d3e6f2	1698083811	at%3Asource=gracenote
8079907	875579	100	35	https://metadata-static.plex.tv/3/gracenote/3df6aff43c56067cc6c43f96b8ebe5e0.jpg			metadata://posters/tv.plex.agents.movie_bd4e23ce6abbdab51f82e0794ca815ceb608b3c0	1698083811	at%3Asource=gracenote
8079908	875579	100	36	https://metadata-static.plex.tv/f/gracenote/fa3d6e3fdc74fbb733f22ad7af616a05.jpg			metadata://posters/tv.plex.agents.movie_db5ed539a5fbb6b82f53057d4214140f84b6d351	1698083811	at%3Asource=gracenote
8079909	875579	100	37	https://metadata-static.plex.tv/e/gracenote/e5b4a2db5b7a1404a56e3dfee71afae7.jpg			metadata://posters/tv.plex.agents.movie_fbe3a52b0195397fcfc624a5d477c7e113b2b53d	1698083811	at%3Asource=gracenote
8079910	875579	100	38	https://metadata-static.plex.tv/6/gracenote/61a48b423a1a92081c1c23aef7232439.jpg			metadata://posters/tv.plex.agents.movie_9466a481729d6d74051035f3f1097f0064105a37	1698083811	at%3Asource=gracenote
8079911	875579	100	39	https://metadata-static.plex.tv/c/gracenote/c9c06d952886c5019babe3756564db60.jpg			metadata://posters/tv.plex.agents.movie_64d030f6e53ea0fa806acfee689b11e757642289	1698083811	at%3Asource=gracenote
8079912	875579	100	40	https://metadata-static.plex.tv/f/gracenote/f31068da51cc02d13d37a7889e469be0.jpg			metadata://posters/tv.plex.agents.movie_749387c9683dd2d3af4a6a7bc6e97ab7eb8300b4	1698083811	at%3Asource=gracenote
8079913	875579	100	41	https://metadata-static.plex.tv/2/gracenote/29d17abf67b83eec2f0b48d329b97fab.jpg			metadata://posters/tv.plex.agents.movie_8d465303cf436355fd14d8c35dd54e419b2f044f	1698083811	at%3Asource=gracenote
8079914	875579	100	42	https://metadata-static.plex.tv/0/gracenote/0a95d62b10f5a26a415b6e0f32c0b096.jpg			metadata://posters/tv.plex.agents.movie_5464aa6411049a85e5aa0904e694914bac09c713	1698083811	at%3Asource=gracenote
8079915	875579	100	43	https://metadata-static.plex.tv/6/gracenote/63a763d23a8942c6d5633533d3a603bd.jpg			metadata://posters/tv.plex.agents.movie_93e2ee74bb5b9ba7ae3264ae9949e8600c361d84	1698083811	at%3Asource=gracenote
@carrousel5301
I have an interesting intermediate result.
Upon recreating your media files (dummy files), I have the following -
[chuck@glockner Carrousel5301.2010]$ ./makedummy ./media dummyfile
Files Created = 327177
Blanks Skipped = 79416
[chuck@glockner Carrousel5301.2011]$
This is inclusive of movies and series.
The number of blank entries is what concerns me most.
Are these entries in media_parts where file is blank?
Yes, and they shouldn’t be.
Are you sure? I just scanned in 2,703 movies on a brand new container using 1.32.6.7557. 53,199 entries with blank “file” column were created. 2,712 entries with something in “file”, I seem to have a few dupes.
