Terramaster F4-220
TOS 4.1.24
Plex 1.19.2.2737
I’m having two issues.
I can’t delete old libraries.
Whenever I try to add a new library, I get a “No Items In Library” message. When adding the library, I can navigate to the folder. I can see the files within the folder. After I add the folder, I scan the library.
I’ve tried multiple things, multiple times and no luck.
Can anyone help?
Thanks,
Plex Media Server Logs_2020-07-06_22-43-26.zip (311.2 KB)
You’ve database corruption.
From Plex Media Server.log:
Jul 06, 2020 22:40:32.412 [0x7fa625a7f700] ERROR - SQLITE3:(nil), 11, database corruption at line 64757 of [bf8c1b2b7a]
Jul 06, 2020 22:40:32.412 [0x7fa625a7f700] ERROR - SQLITE3:(nil), 11, database corruption at line 64798 of [bf8c1b2b7a]
Jul 06, 2020 22:40:32.412 [0x7fa625a7f700] ERROR - SQLITE3:(nil), 11, statement aborts at 24: [insert into statistics_bandwidth (account_id,device_id,timespan,at,lan,bytes) values (:statistics_bandwidth_account_id,:statistics_bandwidth_device_id,:statistics_bandwidth_timespan,:s
Jul 06, 2020 22:40:32.413 [0x7fa625a7f700] ERROR - Exception inside transaction (inside=1) (../Statistics/StatisticsBandwidth.cpp:50): sqlite3_statement_backend::loadOne: database disk image is malformed
Jul 06, 2020 22:40:32.413 [0x7fa625a7f700] ERROR - Exception inside transaction (inside=1) (../Statistics/StatisticsManager.cpp:245): sqlite3_statement_backend::loadOne: database disk image is malformed
Options:
Try to repair.
Restore from backup.
Delete it & start over.
Restoring from backup is probably the easiest, as long as the backup itself is not corrupt.
If you delete the database you will have to re-create all your libraries. Your media is not affected (you won’t lose your movies, etc).
See Repair A Corrupt Database for additional information.
Thank you. This fixed my problem. I tried to use older databases to fix the issue but they just wouldn’t work. I went back to the oldest database and renamed that one. Deleted all the rest. Plex is finally done scanning the files.
system
Closed
October 7, 2020, 1:51pm
4
