Plexamp Aural Fixations suggestion/question (last.fm integration)
Hey there!
I’ve got a suggestion/question regarding the Aural Fixations section. Would it be possible for this to use our last.fm listen history? I’ve only had my current plex server running since like late 2019, so I only have listen data going back to then on it. However, I’ve had a last.fm since about 2016, so I have much more data there that could be used. Plex already has last.fm integration for scrobbling and also uses last.fm as a possible metadata agent, so I’m curious if this would be a possible area for further integration.
Because for me, and I’m sure for others who do not have a lot of listen history on Plex, having the Aural Fixations section use last.fm listen history would be very useful. If this would be an issue due to having to request a lot of information at a time, perhaps we could have an option in our settings somewhere to gather all of our past last.fm listen history at a single time so we don’t have to request from last.fm, but instead can just gather that info directly from the server. The listen history data would likely not have to be updated very often or at all, because I imagine most people don’t have a huge amount of changes happening often in their last.fm listen history.
Thanks!
Technically it’s possible, and an enterprising person could write an import script which modified the metadata_item_views and metadata_item_settings table, but we don’t have the capacity to add it as an official server feature at the moment. Happy to provide advice if someone wants to take a stab!
