Plexamp auto playing a second album
I’m enjoying plexamp and have a question.
I’m most likely just dumb but I cannot figure out how to stop plexamp auto playing a second album. So, I have a artist with 2 or more albums in my library. I decide to play 1 albums and once finished plexamp just auto start the next album.
How do I disable or stop it doing that ? I’d rather it just stop after finishing what I selected to play …
I think there’s multiple ways to achieve that. I usually use the sleep timer and tell it to end playback at the end of the album :wink:
You could obviously also disable autoplay in the Plexamp settings.
That might be what I’m looking for. Let me give it a go and see if its what I’m after. Thanks.
Thanks, that was it exactly. Didn’t see the autoplay option in the settings as I was looking in the auto generated playlist.
You can also swipe (on phone/tablet) the autoplay card for different autoplay options, one of which is “silence”.
Mmmm, can’t see that myself on the plexamp app on android. Could you provide a screenshot?
Thank you, I see it now. Much appreciated.
Read [How To] Plexamp 3.0
Take this as feedback and NOT criticism. I had looked at that doc but its difficult to read and I guess I missed it. Its poorly structured and should be migrated over to a proper support article broken up into logical sections with links.
