Hello there, basically as the title says - would it be possible to have PlexAmp pre-load the next couple of songs (For example 10) ?
This would primarily help for slow remote servers that takes a few seconds to spin up to get the data - could also help if you pause a song for a long time (enough for your disk to spin down) and then you hit next - at which point you gotta wait for the disk to spin up again.
