While I see the repeat button when a song is playing from my play list, and if I press it while a song is playing from my play list it repeats that song, how do I set the playlist to repeat/loop?
When you tap it once, it turns yellow. This means the whole play queue is repeated.
Make sure the play queue actually contains more than one song if you want to use it that way.
If you tap it again, a small 1 is added in the middle, which means only the currently playing track is repeated.
If you tap it once more, normal playback is restored.
i.e. it behaves just like the majority of other players.
Well, that’s what I thought so there may be an issue with PlexAmp as I have repeat turned on (no “1” visible) and it’s not repeating my playlist, it just stops playing and doesn’t repeat.
