Maintain repeat selection even if skipping to next song in plexamp
RE: Plex Amp
Love this app. Makes listening to my music very simple and enjoyable. There is one feature that is missing for me and keeping me from using the app regularly. I like to listen to songs on repeat and althought the repeat function is present and works well, when I click to the next song, my repeat preferences erase to the default “no repeat” setting.
The shuffle setting remains as selected (which is awesome!) But I wish for the next song to keep repeating based on the selection I had made and not reset as well, like the shuffle setting that keeps my selection even when going to the next song. I want it to remember my repeat choices even when skipping through songs. Is this a function/setting we can implement in future updates.
Which version of Plexamp do you have installed and on what platform?
From what I remember there should have been a fix for that when version 3.8.1 had been released.
3.8.2
Sonics Nas
Dsm 7
I’ve since learned that repeat-one will indeed be disabled if you skip or select a different song. That’s by design.
The “normal” repeat function should remain selected.
Hoping the feature request can help maintain repeat 1 selection
Any plans on updating this feature?
I don’t know of any plans (Plex usually doesn’t comment on their roadmap). Also keep in mind your suggestion doesn’t seem to have gained much attention/support (votes) from other users – so not sure others consider the current behavior to be an issue :frowning:
Thanks for replying. Any way of incentivising this. I wouldn’t mind paying to have this feature included in an upcoming update
Sorry… that’s not how feature suggestion work with Plex.
Thank you
